20 Most Recent Samsung SyncMaster 17" LCD Monitor Questions & Answers
Auto adjustment box keeps popping up
Use best quality data cable directly from VGA card to LCD input and your problem will be fixed.
Usually that problem oocured when we use external tv device with CPU and monitor so signals gets weak and auto adjustment popups.
1/22/2013 11:29:39 AM • Samsung... • Answered on Jan 22, 2013
My samsung lcd monitor have a dim light.. i cant
It is possible that the monitor settings have changed. There should be a menu or settings button on the monitor. Try to increase brightness and decrease contrast.
Unfortunately, it is much more likely that your monitor is failing and needs to be serviced or replaced. Given the price of monitors replacement is probably the least expensive solution.
I hope this helps. Good luck!
3/26/2011 2:13:46 PM • Samsung... • Answered on Mar 26, 2011
My samsung screen goes blank after 2 seconds but
Low the resolution on the machine and see if you have the same results. Update the Graphic card drivers if you can.
3/5/2011 6:01:13 PM • Samsung... • Answered on Mar 05, 2011
AUTO ADJUSTMENT LOCKED BOX FLASHES ON THE SCREEN ALL THE TIME.
Depends of what seems to be a problem.
If you want to get rid of that message box, appearing by itself, then probably you need to take front panel PCB with buttons and replace "Auto" one, 'cause it's stuck.
If you want to unlock an Auto Adjustment and other functions in your monitor, then press and hold 'Enter' button for 5 seconds.
9/14/2009 7:12:02 PM • Samsung... • Answered on Sep 14, 2009
Contol lock
Cap or Scroll lock?
3/22/2009 10:18:01 PM • Samsung... • Answered on Mar 22, 2009
Unable to turn off moniter
i finally just gave up and called samsung. 1-800-samsung
they took me through some steps to see if that would work. gave them model number, etc. there is some defect apparently in that model syncmaster731n. they are sending me a new one, and i have to send the old one back. they are paying for shipping, and not charging me for the new one. so if it is bothering you, i would give them a call and see what they tell you. hope this helps someone out there.
9/1/2008 2:03:04 PM • Samsung... • Answered on Sep 01, 2008
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
4/22/2008 12:51:08 AM • Samsung... • Answered on Apr 22, 2008
Samsung FX2490HD 24" HDTV LED Backlit Widescreen Monitor. Can I factory reset my Syncmaster FX2490HD
It sounds like you are in the Store Demo Mode. Turn it off and see if that fixes it. https://www.manualslib.com/manual/145519/Samsung-Syncmaster-Fx2490hd.html?page=27 Reset
Reset Samsung FX2490HD LS24F9DSM to factory state
monitorsfaq.com https://www.monitorsfaq.com > Factory reset > Samsung How to restore or reset Samsung FX2490HD LS24F9DSM. Reset to its factory state Samsung FX2490HD . How to hard reset monitor. Clear all settings or format. ..
8/7/2023 6:46:52 PM • Samsung... • Answered on Aug 07, 2023
How to fix pink colur screen on sync master 794 mg samsung
The connecting cable or the video card would be the first suspects. Try a different cable to connect the monitor first, if there is no change, the video card in the computer would be second to look at. Can simply connect a different monitor to your computer to troubleshoot this. If the testing monitor works, it will be the graphics card that is the issue.
6/19/2022 1:41:48 PM • Samsung... • Answered on Jun 19, 2022
How to adjust brightness for samsung syncmaster
5 year old hyjacker, vinay. you forgot to say connected to what? is the screen only dim or dead.? even more important clue. RTM read page PDF 17, ? the OSD screen must work or the monitor is dead http://downloadcenter.samsung.com/content/UM/201205/20120517112305649/SA10-04Eng.PDF base pages https://www.samsung.com/us/support/owners/product/lcd-monitor-a10-series
9/12/2018 10:52:46 AM • Samsung... • Answered on Sep 12, 2018
0answers
0answers
6answers
Model 205. How can I update it to allow Windows 10 to install?
Press the auto key of your monitor to get the best fitted resolution for your window, each monitor has a limited graphic capability of which it is designed. if the production is not ok consult your manufacturer.
7/5/2016 7:23:05 AM • Samsung... • Answered on Jul 05, 2016
0answers
Ls22a350
Be the first to answer 5/15/2015 7:20:27 PM • Samsung... • Posted on May 15, 2015Be the first to answer
Vga connection to the mother board
If your motherboard doesn't have a VGA connection, then that means it most likely does not have an integrated video card. If this is the case, then you will have to purchase and install a video card. It is very easy and your local Best Buy should be a great resource. The geeks there are usually very enthusiastic about explaining how to do it. I use to order from newegg.com, but they have become very commercialized and overpriced, like Best Buy. You can check tigerdirect.com or my favorite Amazon.com. Best Buy will price match any items they sell, including those on Amazon. If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_3e83613ef5f2a68b
3/13/2015 12:06:38 PM • Samsung... • Answered on Mar 13, 2015
Samsung SyncMaster 17" LCD Monitor Logo
11 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
auto adjustment box keeps popping up
  • Computers & Internet
