A microtek 14"inch monitor. there is power on, but no display on screen.is there a eht problem or h-out, capacitor, or may due to moisture.
SOURCE: Samsung SyncMaster 793MB 17 in.CRT Troubleshooting
remove EHT wire and clean that area with spirit or isopropal alchohal. dry it . if neccessary replace the EHT cap. apply JELLY (like vasiline)at EHT cap and at CRT where EHT placed. if possible spray the ecrilic.dry it and it will never gives trouble like this.
SOURCE: Microtek 997M monitor doesn't stay on...
The inverter is the most common item to fail on a LCd monitor. Capacitors usally fail the most. Are the tops of any of them popped up. If you had any shorted transistors the fuse would probably be blown. Usally labeled F1. I would replace all the capacitors first and go from there. Capacitors are cheap.
SOURCE: Monitor screen is vibrat left-right & up-down side
just go to the menu of your monitor then try to reset the setting so it will set the factory default value
hope this will help u
this is due to the abnormal 5v supply to micom.check upthe 5v line.
SOURCE: 700e Lg crt monitor problam power on eht on but not display
Un Plug the vga monitor cable to cpu.. if the monitor working good the OSD is appeard. If the monitor no display or OSD but the power LED is normal i think this is ABL problem. If you are the electronics or computer tech. repairman you understand what i mean.
email me or visit blogger.com i sent to you the complete sol.
[email protected]
[email protected]
