20 Most Recent
Microtek 710S 17" Flat Panel LCD Monitor Questions & Answers
My Microtek 710S Monitor screen goes black if left
Check the power setting of your PC.
- If you are on windows;
- Click on start button
- If you have vista or windows 7, type "poweroptions" into the search bar.
If not, open control panel and find the power options inthere
- In "power options" you can change when the displaygets turned off and when your PC will go to sleep, just change these settingsto the time you want, e.g. 2hours
I can offer support for other OS if required
No real problem. just
You should have settings for these via a "MENU" button on the Monitor or if you have an "optional" display card, there should be options in the "Display Driver software". Mine uses an NVIDIA GForce, Driver, and it has these options. You should be able to find this under "All Programs" in the Startup Bar - Look for something that indicates "Monitor" or "Display" in the program name.
When turned off for the night, it takes forever
Maybe your monitor's having trouble getting power. Try plugging it out, and then in again. If that's not working, call you're monitor's manufacturer (if you don't know the number, try searching on the internet). Or maybe that's not the case. Maybe your PC takes time sending the signal to monitor. Call the computer's manufacturer (if you don't know the number, try searching on the internet).
Hope that helps,
Daniel
Monitor wont go on when the tower is on.
A few steps you can do to try to remedy this:
1. Is the monitor on? Sounds simple, but it's happened to me before! 8)
2. Try another monitor. If it works fine, then it is clearly your monitor that is the problem, and not the graphics card in your computer.
3. If it is your monitor, try using another signal cable or another power cable. Unfortunately, if neither of these solves the issue, the problem is most likely within the monitor, and will not be easy to fix (read: you will most likely have to replace the monitor).
Dialogue box in the middle of the screen
Out of range usually means that the computer is trying to use a resolution that is unsupported by the monitor. Try loading the PC in safe mode (for windows, press F8 before windows loads) and change the desktop resolution to 800x600, which is supported by pretty much any monitor. Restart the computer normally and you should get your video. Once inside windows you can experiment with different resolutions, and when it goes out of range, just wait 15 seconds for it to go back to 800x600.
