Cameras Logo
Albert Strimel Posted on Nov 20, 2011
Dropped camera & lost shutter button.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 20, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
60
Points
6
You might of messed up your speaker in your camara.
Shutter button does not work after camera was dropped.
You dropped it and that is the problem, it is junk. Repair cost will exceed price of good camera.
Shutter will not open
You're only hope is probably to remove the battery, press the power button a few times to reset any components & the try it again.
How to release a stuck sutter on canon 400d
Wow, four days ago.
I would think that the camera has dropped the shutter by now.
There is a mode in the camera that holds the mirror up out of the way for sensor cleaning but this is defaulted as soon as the power is shut off and then turned back on again.
Or the camera was set in manual mode "Bulb" and is waiting for the next command from the photographer to "drop" the shutter "takes a second press of the shutter button.
The lens may be loose (unlocked) and giving a bad command to the camera.
The Canon 40D has a shutter capable of 60,000 actuation so if you are close to this I'd say the shutter has been shot out of it.
Also sometimes the shutter release button sticks and gives the feeling or appearance of a stuck shutter.
Shutter switch also known as a release button have been an issue sometimes where dirt and oil from a person hands get down into the button.
To release shut the camera off, take the battery out, remove and reinstall the lens, shift the taking mode to "P" program or full automatic green box.
1helpful
The button for taking photos and zooming in fell off and is lost can this be replaced?
Hi, I've had the same problem - there are 4 legs that clip the zoom button on (which holds down the shutter button) and the ends of the legs snapped off. I didn't drop it or anything, just one day when I got the camera out the shutter button fell right off.
If you're in the US you can get a replacement part from here:
http://www.pacparts.com/model.cfm?model_id=EXZ110&mfg=CASIO&back=0&action=list_part
I think the part no: 10213210 is what you're after. Note that it's $8.50 (USD) and then they charge $11.50 (USD) to post it to you!
Unfortunately I'm in NZ and they won't sell it to me.
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Camera turns off when shutter button is pressed.
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
1helpful
Shutter button repair
hi it depends on where it broke and if...(the button) if it just fell then u can just take the new button a shove it in untill theres a CLICK if its broke then u will need to pull out the rest and then shove it in DO NOT TRY TO OPEN THE CAMREA IF U DONT KNOW HOW!! you will brake the pins inside when u will and then it will cost u as a new cam good luck windman
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
