There are a couple options: 1. Your keyboard is broken, you need to replace it. 2. Try unplugging / replugging it un and or restarting your computer, that may fix the issue. 3. Your keyboard layout might have changed. If you are using a Windows computer, you can press CTRL + SHIFT to switch between layouts. Or you can go to Control Panel -> Clock, Language, and Region -> Change Keyboards or other input methods. From here, you can change your keyboard layout back to use.
Go to control panel->regional and language options -> Launguages
tab -> then as i guess you are in the UK add the UK layout and delete
the Us layout. You may press and Hold the ALT Key and hit the numbers lock key, It should go back to a
normal keyboard after restarting the pc..
About themes
Depending
on your wireless service provider, you might be able to set a theme on
your BlackBerry® device that changes how items such as applications,
indicators, words, and icons appear. Themes might be preloaded on your
device, or you might be able to download themes that are in .cod file
format.
Switch themes
From
the Home screen, press the Menu key.
Click
Options.
Click
Theme Options.
Click
a theme.
To
change the layout of the theme,
in the Set Home Screen Layout section,
click an option.
Click
Save.
Delete a theme
You can only delete themes that you have downloaded to your BlackBerry®
device.
On
the Home screen
or in a folder, click the
Options
icon.
Click
Theme.
Highlight
a theme.
Press
the Menu key.
Click
Delete.
Download a theme
Depending on your
wireless service provider, this feature might not be supported.
On
the Home screen
Options
icon.
Click
Theme.
Press
the Menu key.
Click
Download Themes.
THEMES FOR UR MODEL http://gallery.mobile9.com/c/blackberry-storm2+9550-themes_2570/1/
Go to received calls, press the centre button & you will get a menu, where the first option is Delete (for the first entry) and the second option is "Delete All".
Go back and select "Dialled Calls", again press the centre button for the menu with the delete commands.
Well, goto your pictures (Usally a key on side) Click "options" and view photos, then select the photo you want to delete
Click "options" and usally it says delete, or modify, then delete
