20 Most Recent
Motorola Mobility ROKR E6 Smartphone Questions & Answers
HOW CAN I DOWNLOAD GAMES AND THEMES
are downloading straight to cell (you need a data plan from your
carrier, go to download and games) this will cost $ depending the size
of theme/games and time it takes to complete.....okay #2 this way is
using a laptop/pc you will need a usb cable (to fit pc) to a mini usb
(compatible to your cell), go to site you wish to download game / theme
download to pc........then connect cell to pc via usb go to my computer
open cell...copy / paste (make sure any games downloaded is placed in
the games folder on cell, themes placed in themes..
try this site also
1/23/2019 7:33:58 AM •
Motorola...
Answered
on Jan 23, 2019
My phone is not charging. when the charger is
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
12/30/2016 6:17:47 AM •
Motorola...
Answered
on Dec 30, 2016
Dear sir, my phone is problem with virus
hi
first of all try to connect the mobile with computer and then try to take all the back updata on a particular folder and then try to delete the the data from mobile and once it is being done then try to scan the computer and once the virus scann is completed and is succesful then try to transfer the data back into the mobile
IF it doesnot work then try to log on to
http://techbuddies.org
they will remotely help you out for you computer
10/31/2016 6:33:23 AM •
Motorola...
Answered
on Oct 31, 2016
I have lost my moto
Try a hard reset under settings/ initial setup / master clear
code should be 000000
this will wipe all memory and reset your lock code
CommCentral
12/21/2015 6:34:24 AM •
Motorola...
Answered
on Dec 21, 2015
Where do i put the code
Views
Having lots of logic in your views is a huge anti-pattern. Don't do it. It's hard to test, it's hard to find, it's hard to write sandwiched in between the HTML... Just don't.
Instead, your views should contain HTML, variables that turn into HTML, and calls to helper methods that generate HTML - or whatever your final output format is. There should be no logic in there
to test. No conditionals, no loops, no non-display methods. If you add an output format, there should be no code to repeat because all the interesting data transforms already happened, and no other output format cares about your HTML-only helpers. Right?
12/14/2015 1:42:01 AM •
Motorola...
Answered
on Dec 14, 2015
