Tell you what. I will link you to the quick start guide and the users manual for the X4-T. Read over them and get beck to me with any specifics you may have.
Did you disconnect from some sort of USB device without umounting it first?
Have you tried starting up in Safe Mode?
Can you give us a clue to what device you using?
Have you updated to the newest software?
Do you have any program running that might cause problems...such as a Launcher?
One of the first things I check on any heating device besides the element is the High limit switches that only allow the element to work if the heat stays below a certain degree range. They areon furnaces, dryers, wall heaters, etc. They usually look the size of a small coin abouit 3/4 -1" with little wings on the side to for screws to secure them. That may be your problem.
First, turn off the device, second, take out and put the card back in, third, turn back on the device and this should work. If the game is for the Game Boy Advance, do the same but in step two, blow into the cartage to remove any dust partials before putting it back in.
'No Humidity'-- sounds like the humidifier is NOT adding moisture to the room it is running in?
Can you give us some clues?-- Like-- How is the pad look inside? Are the fan(s) running? are there any indicator lights lit? Did it work for awhile, and stop? What stopped first?-- the fans, or the little rotating wheel? any clues that happened at the time it quite? When was the last time the unit was opened up and cleaned out? These devices need regular maintenance-- they build up mold and scale.
I have the same problem and it won't change channels after the 1st program. I just leave the cable box on. This is not the best answer but it works for now.
first thing connect your phone to AC power (electricity) then see if the charging indecator is red or orange or green , then try to start your device if it's not working the problem is hardware and go to a pepairmant workshop , if the indecator doesn't work and there is no light try to change the battery with a new one and then do the stpes agian
