My screen is frozen white,when i plug it in to my computer,no files appear. when i plug it in to charge,the light DOES turn red,but still is frozen white. when i close,the screen into the camera,the screen is still on (AND WHITE!)
please help.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
go to the main menu click on setting then click onsystem then click onlanguage then click english and mine freezes on me also what ill do is try to cut it off then i put it on the charger then ill go to sleep wake up the next morning and itll be off and unable to turn back on so i plug it up then it starts charging(it only does that to me when the battery is low)and if you turn it back on the screen is gonna pop up with the computer and the plug and it's gonna stay frozen until you plug it up to charge so you change the language and charge it basically.. your welcome i hope my solution helps
I had the same problem. What you need to do is open the Leapfrog connect and then plug your DIDJ into the computer. You also need to plug it in with the AC adapter as this takes time and the first time I tried the batteries died. So plug it in or put new batteries in it. Now just leave it sit plugged into your computer with the Leapfrog connect program open. It took mine almost 2 hours just sitting on the white Warning screen then if finally connected and updated the software and is now working fine. Hope this helps.
Try this: Press and hold the wake/sleep button and the home button simultaneously for ten seconds and the apple logo should appear on the screen. Release the buttons and it should work like normal. Hope this helps.
I had the same problem. Just wait until the battery will be out of charge and then charge it again with your computer. Turn it on and you go.
(Sorry for my english, i'm french)
