SOURCE: how do i manually configure
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
SOURCE: How can we reset the
Contact your System Administrator or System Vendor. That is the only way to reset a password on the system.
SOURCE: Hi =) I have a mitel 5224 which i connect to my
the stand requires configuration to tell it how to connect to your Wireless router. The default IP address is 192.168.1.20
The firmware should be upgraded to 2.0.3.ap51. This provides for better security and more options.
SOURCE: What is the pinout for the headset port of the
No idea. Contact Plantronics for a headset. This phone will support a variety of headsets. www.plantronics.com.
