SOURCE: Unable to open BIOS Setup
Are you trying to change the boot up drives so that the CD boots up first so you can do a repair or reinstall Windows?
Try F2
You can select from a list of bootable devices by pressing F12
SOURCE: laptop bios password , not going on bios setup
Remove the Bios Battery and let it sit for 15 minutes...
I had this problem and that cleared it.
Enjoy!
SOURCE: i made in bios a
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
SOURCE: setup menu is invisible
You might have a virus in your master boot record. Do the following:
Download
The following iso listed below. It is the latest version of the
Kaspersky rescue disk. You need to burn it to a CD with a program like
Imgburn (Which is also FREE like the iso file). Then you need to boot
from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
