SOURCE: The scrollbar on touchpad in my Compaq C-772TU
You will need to install the touchpad software (ALPSTouchpad Pointing Device Driver) for the Compaq Presario C772TU Notebook PC.Below are the download links
Microsoft Windows Vista
File name: sp38629.exe,(8.02M)
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38629.exe
Hope this helps. Please rateyour feedback!
Thanks,
VJ
SOURCE: my touchpad on my compaq laptop wont work how do i
You probably need to re-install the driver for the touchpad. Go to the Compaq support site and download the driver for your computer.
The pad is something like an ALPS, but you can search for drivers based on your exact model.
SOURCE: my compaq laptop touchpad is not working properly
i have compaq c700 with win 7 the touch pad not work
SOURCE: Automatic scroll does not work on touchpad unless you hold down the left click button
This can be set to scroll for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Virtual Scrolling"
Check the box beside Vertical Scrollong and then click OK on this window and the mouse window.
Close the control panel and you're on your way.
I hope this helps Fixya,
Chris
SOURCE: Entire Keyboard and Touchpad don't work! Compaq Presario CQ60
Fantastic, thank you for posting above that removing the battery sorted the problem. I had exactly the same problem as you with being able to sign in with my password but neither the keyboard or touch pad worked past this point. It's weird that the keyboard worked for signing in with the password but then didn't work anywhere else. Wonder what causes the problem coz I can't think of a logical explanation. Anyway I didn't have to hold the on/off button down for 2 mins. Just removing the battery and then replacing it cured it. I can't thank you enough for helping me to solve this.
