Amana PTC153B35AJ Air Conditioner Logo
Anonymous Posted on Sep 27, 2011
I have a PTC153 A50AC that the heat will not kick in
How can I disconnect the heat on a Sanyo heating air conditioning wall unit 12000 but.
no info generic answer check and test thermostat and wiring circuit fan & heat should not be coming on when in a/c mode
1helpful
2answers
I have a heat pump and a Honeywell thermostat and the emergency heat randomly kicks on
The emergency heat likely randomly kicks on when your heat pump enters defrost mode.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
I have a airwell GC-30RCC when put on heat the fan on the indoor unit wont kick in it works fine on cooling and plain fan mode but not on heat mode the red fan light is on too
How do you get it to kick in ?.Fid you spin it by hand ,if that's what you did and fan runs then you have a bad capicator. If fan runs fine in cooling and not in heat then you have a bad board
Furnace will not kick on. air will not kick on
check thermostat setting. make sure unit is on! when u say "air will not kick on"? are you saying the heated air is not blowing out? if no hot air, there is no heat to blow out! fix furnace!
1helpful
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Heat kick on then off
these are heat cycles,
the click you are hearing is the thermostat turning the element on or off, most dryers try to acheive a temp of 160 - 180 degrees, when reached the element shuts off for a bit to cool down and not scorch your clothes
you do not have to worry about this
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
