20 Most Recent
Amana PTH153B50AE Air Conditioner Questions & Answers
I have a AMANA PTh153B50AE
I have the same problem, and I found the manual reset inside the unit. Turn the power off, and unplug the unit. Remove the outer cover of the unit ( inside cover ) , and remove the 2 screws holding the " wire mesh " in the front of the cover. Pull the wire mesh up and out of the way, then carefully pull out the heating element.
On the heating element, where the wires are connected, there is a manual reset button... Push the button in, till it resets...
My reset was on the upper left connection of the wires... just looks like a small push button, but the reset is recessed a bit.
Replace all covers and plug back in.. working fine..
1/29/2015 2:49:54 AM •
Amana...
Answered
on Jan 29, 2015
Compressor wont turn on
first check you thermostat settings and make sure that it is on a cooling setting if ok it can be the fuse that sends the power to the outside unit if fuse is ok it can be the capasitor for the compressor if ok you may have to check the compressor for open windings or ground fault so you will have to replace the compressor or the relay which is after the thermostat
5/3/2010 4:52:31 PM •
Amana...
Answered
on May 03, 2010
My Amana package system fan only blows cold air
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
10/20/2009 9:20:46 AM •
Amana...
Answered
on Oct 20, 2009
No heat
check to see if unit has a contactor,they arc and weld together,keeping your unit on
3/25/2009 10:05:36 AM •
Amana...
Answered
on Mar 25, 2009
Amana pth153b50a
I would try
www.sears.com parts dept...have make and model ready!
Please rate! !this is how we keep this website free
Thanl you!
12/13/2008 7:05:48 PM •
Amana...
Answered
on Dec 13, 2008
Our heater blows cold air.........
most boards have a small 3 or 5 amp fuse on the board it looks just like a car fuse. do not put in wrong size fuse it can allow damage to the board.
11/24/2008 1:45:08 PM •
Amana...
Answered
on Nov 24, 2008
I'm not getting any code after installing a control board for my Amana ptac?
Does the power light come on?
If yes, then you can do a reset as below:
There is a master switch on the bottom left of the control board. Slide that to 'off' position.
Then press the hot and cold switch/key together and then slide the master switch back to 'on'.
Please put your response/observation here if that does not work or there is power light as asked on top.
Thanks
Amana PTH153B50AM PTAC where the heat runs intermittently.
i'm not familiar with your specific unit but ..sounds like an electronic gas value has gone bad or has a bad connection when that happened to my friend it wasn't that expensive to have it fixed .. BYW it acted like this for a while then stopped working completely
