20 Most Recent Whirlpool RBS275PD Electric Single Oven Questions & Answers
Type your model number into the web-site: "Searspartsdirect" and you will find the schematics for your model oven, and the ability to download a manual.
God bless your efforts.
Whirlpool... | Answered on Sep 10, 2018
This means you have a bad temperature sensor.
This is a very simple part to replace so you will save a ton of money by replacing this part on your own.
search for codes on Google
Whirlpool... | Answered on Sep 09, 2018
These answers are not a solution to the problem!!!!
Whirlpool... | Answered on Aug 30, 2018
You would need to determine if the clock / control is sending voltage to the bake and broil elements. If not, clock will have to be replaced.
Whirlpool... | Answered on Jan 01, 2018
you don't have a thermostat that you turn,you have a computer board or clock assy. unfortunately you can't get parts for this oven because it's to old and they stopped making parts for it.when you use the self clean the oven gets up to 1000 degrees and this can damage the electronics in the unit and it sounds like it took out the computer board,there's also a thermal fuse inside that could have popped but common problems with self cleaning is the board gets damaged.you might be able to have a tech come in remove the board if that's the problem and he'll make a diagram for the board,then you send the board out to have it rebuilt,you can google this to find a company that does this,when it comes back rebuilt the tech will rewire it and this should take care of your problem but like i say you can't get parts for this anymore so do you want to sink 3 to 400 dollars into it.also when ever a holiday is coming up don't ever self clean your oven,people do this right before the holidays and then something like this happens and the parts have to be ordered and it could take up to 2 weeks or more to have it repaired,i would never use self clean do it by hand and with easy off.hope this helps you out and good luck with your oven
Whirlpool... | Answered on Nov 11, 2017
When you use your self clean feature, your oven heats up to over 800 degrees and this normally takes your electronic computer control board out.
Whirlpool... | Answered on Sep 13, 2017
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Whirlpool... | Answered on Sep 12, 2017
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock).
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
Whirlpool... | Answered on Aug 23, 2017
Hello Sonya,
The E0-F2 error code means that the oven temperature was higher than it's supposed to be. Usually the oven overheats because of a defective oven temperature sensor and the sensor should be checked. 11_3_2011_2_07_54_pm.jpgthis is what the sensor looks like...it is located within the oven chamber(usually in the left side) to check it,it needs to unplugged and using a mulitmeter set to measure ohms,check the sensor to be between 1060-1100 ohms at room temp. if the sensor is way lower/higher that 1060-1100 at room temp the sensor is bad and needs to be replaced, if the sensor is within that range then the control board is the problem.
GENE
Good Afternoon! If your Whirlpool oven isn't heating to temperature, and your temperature sensor is reading good, the control board may be the issue. Fixyourboard.com can test and if necessary repair the control board in your oven. We back all control board rebuilds with an industry leading two year warranty. Contact us for more information- info@fixyourboard.com
Thank you!
Whirlpool... | Answered on Jun 06, 2017
change temp control
Whirlpool... | Answered on May 05, 2017
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Whirlpool... | Answered on Jan 03, 2017
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Whirlpool RBS275PD Electric Single Oven Logo
380 questions posted
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Ovens
  • Whirlpool Ovens
Most Popular Question
code f1e2 whirlpool electric range mean
  • Ovens
