I would suggest that you go through this guide, it will explain you every step which you need to make to get your modem and internet connection back on track:
The ultimate Link Troubleshoot guide: Problems. solutions, PDF manuals
SOURCE: Can't remember password
If this is a router with included wireless, you can physically connect via a hard wire to the unit, bring up the computer, and go to a DOS prompt (START, RUN - in the box type CMD followed by RETURN or ENTER), in the black box type IPCONFIG/ALL and note the GATEWAY address. In a web browser, type the GATEWAY address. It should prompt for the router access. From there, you should be able to see and even reset the WEP or security key found. If you need to reset it, you can reset it by pressing a button on the back of the unit. It is a very small pin-hole type accessible by a paperclip.
SOURCE: forgotten password for D-Link DSL G604T wireless router
These are the default settings:
When the login window appears, set the user name to Admin and leave the password box empty. If this doesn't work, you may also try admin for both username and password (all small letters).
If the default doesn't work, you may reset the password by pressing the reset button for 30 seconds. This will bring the router to factory default settings (including all the configurations set on the router).
Hope this helps.
SOURCE: HOW TO INSTALL THE D-LINK WIRELESS ADSL ROUTER
Go with default IP address and configure it.
keep in mind,your network should match the IP address..
SOURCE: My D-link G604T connects with WEP but not with WAP
You should connect manually. For do manual connection use following link, where you will find the complete steps :
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Regards
Ashly
