20 Most Recent
D-Link DSL-G604T Wireless Router Questions & Answers
D'link dsl router 2760u wifi password
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
I get a yellow triangle
Usually mean you are not connected to the internet either not to the internet modem or the modem is not connected. Try a fresh LAN cable between the modem and router. Make certain your modem is connected to the internet and working - if not check with your internet provider. Reboot you router.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
I want to make security key
Go to the wireless network section using your browser to login to your router. There you can setup your network password/key.
Username, password of my model DSL-G604T/TH V.A3
The default login to the router is ADMIN and the password is blank. If yo are looking for the wireless SSID and password, that should be listed (after logging ton the router) under the wireless section.
I cant log in to my d-link router
Here is a link to the manual, it should explain how to change the settings:
http://www.dlink.com/-/media/Consumer_Products/DSL/DSL%20G604T/Manual/DSL_G604T_Manual_EN_UK.pdf
I cannot connect to the
you may wanna contact your service provider. and ask if they see any issues on thier end and if not support you to get your connection back up and running
Port forwarding
Instructions are on this WEB site.http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
Linksys port forwarding
This WEB site shows how to port forward.http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
HOW TO Connect tl-740n wireless WIFI router to PTCL DSL WIFI ROUTER
The easiest way to chain two wireless routers. *Please note this is just to have wireless access*Make sure DHCP is enabled for both, make sure their SSID (the name that shows up when you connect to it) is different.Make sure they are both different networks. So for example configure the first for 192.168.0.0 network and the other for 192.168.1.0. Now plug an Ethernet cable from the 740n router (WAN) port into a (LAN)Second method *This only works if the tl-740 router supports AP mode (Access point).In the configuration of the 740 router, enable AP mode and make sure DHCP and nat are turned off if they are on. Configure the wireless to operate on channel 1 6 or 11. Name the SSID the same as the other router. Plug in Ethernet from WAN 740 to LAN on the other router. Now on the DSL router make sure the SSID is the same and select a different channel from (1,6,11). Now you're all set.
UNABLE TO ACCESS OLD PASSWORD FOR D-LINK WIRELESS MODEM
Just reset your modem... unplug and press and hold the button the plug it while you're still holding it for couple of sec then release holding it. make sure you plug it to your computer it may show some msg on your screen etc. and just follow it if there is..
How do we secure our Wireless router Up until we
1. Navigate to router's web interface<br />
2. Login, click to Wireless button<br />
3. Select WPA radio button as Security<br />
4. Select Pre-Shared Key radio button and type some password to PSK String field<br />
5. Click Apply button<br />
6. To save and reboot the Router, click on the Tools directory tab and then click the System button. In the System<br />Settings window, click the Save and Reboot button under Save Settings and Reboot the System<br />
<br />
DSL-G604T doesn't have built in MAC access list and may hang on heavy usage. To optimize it for stable and safe connection use Router Commander program from <a href="http://www.routercommander.com">http://www.routercommander.com</a>, with it this router shows very good <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: HE">performance </span>and stable internet connection.
