I cant give you an exact date but it is from the early 70s. That is when they were yellow. My educated guess on this is 1973. If you go to a Massey Ferguson dealer with your numbers they will gladly tell you what year it is exactly.
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
The drain in the freezer behind back lower panel needs opening. You can see it at the bottom of the back panel underneath the evaporator coils. (The cold coils) Run Hot water in the drain until it clears or use a hairdryer. When the defrost melts the water it goes down the drain If the drain is clogged with Ice or ? The defrost water overflows into the ref. or freezer Run Hot water in the drain until it clears or use a hairdryer. Also check fan undernearh Ref in the rear Clean condenser coils underneath .I'm including my article on Refrigerator Repair for your help and convenience.; Please click or copy and paste into browser for Article http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically Thanks for using fixya Leo Ponder imufo2 Please VOTE FOR ME IF THIS WAS HELPFUL
Hi, First I would check the fan in the freezer. Listen to see if it is running It moves air to the ref from the freezer Then check to see if freezer control is turned WARMER, which makes the Ref. colder Also this might be a common Defrost problem, Ice is not being melted by the defrost system.The fan can't blow through the coils into the fridge. Take out back panel of freezer to check for ice buildup. The coils should be clean. There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card. Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check fan undernearh Ref in the rear Clean condenser coils underneath .I'm including my article on Refrigerator Repair for your help and convenience.; Please click or copy and paste into browser for Article http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically Thanks for using fixya Leo Ponder imufo2 Please VOTE FOR ME IF THIS WAS HELPFUL
Hi, I'm Leo First I would check the fan in the freezer. Listen to see if it is running It moves air to the ref from the freezer Then check to see if freezer control is turned WARMER, which makes the Ref. colder Also this might be a common Defrost problem, Ice is not being melted by the defrost system.The fan can't blow through the coils into the fridge. Take out back panel of freezer to check for ice buildup. The coils should be clean. There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card. Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check fan undernearh Ref in the rear Clean condenser coils underneath If this was helpful please rate me Thanks for using fixya Leo Ponder imufo2 Thank you for using fixya Leo Ponder Please VOTE FOR ME IF THIS WAS HELPFUL. I'm including my article on Refrigerator Repair for your help and convenience.; Please click for article http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
I will give you a easiest way for finding the drivers that you need for
your hardware.Just download the software named driver magician.Install
it and it will search for the drivers that is not installed for the
hardware you have through internet and will download it for you.
Yes, you can refill your cartridge, but it doesnt help your problem. You need a validation card for each cartridge changeing. Once card you can use only for 2 cartrideges...indeferent that's new or refilled.
