Start up WinMX and go to Settings, then press the Setup Wizard button. When prompted to clear all previous settings, select No. Now you can click next through the screens (your previous information will still be there) until you get to this screen: Click on Cancel Test / Manually Configure. Click No. Do not use a proxy server for outgoing connections and then click Next. Enter 8888. Click Next. Enter 9999. Click Next. Finish the setup wizard. You will need to open (forward) 2 ports on your D-Link router. After you configure your router, you must restart the WinMX software. Step 1 Open your web browser and enter the IP address of your router (192.168.0.1). Enter username (admin) and your password (leave blank). Step 2 Click on Advanced and then click Virtual Server. Step 3 Create a new entry: Click Enabled. Enter a name (winmx). Private IP - Enter the IP address of the computer you are running WinMX from. Select TCP for Protocol Type Enter 8888 for both Private Port and Public Port Click Always or set a schedule. Step 4 Click Apply and then Continue. Step 5 Repeat steps 3 and 4 but name it winmx2, select UDP for Protocol Type, and enter 9999 for both Private Port and Public Port.
