20 Most Recent D-Link DIR-300 Wireless Router Questions & Answers
you don't need to install a router on a PC. The wireless card or ethernet cable should talk to the router.
D-Link DIR-300... | Answered on Aug 28, 2018
Connect a laptop wired to the N300,
If you cn go online it aint a router issue
Second try going online with a laptop
Third check the Signal Type
B/G/N
Keep it to automatic
Disable Router PIN
Try Different Security WEP/WPAPSK/TKIP
D-Link DIR-300... | Answered on Jul 08, 2017
This should be from your internet provider:
usually it is a email and a password.
Sometimes you must use the login info on your modem
Your ISP should be able to supply this info.
D-Link DIR-300... | Answered on Jan 07, 2017
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
D-Link DIR-300... | Answered on Jan 06, 2017
You do not need the disc. Using you browser, login into the router using the default IP 192.168.2.1 unless this has been changed and you should be able to configure your router.
Download English language firmware from D-Link.
D-Link DIR-300... | Answered on Mar 07, 2015
Reset your wireless router to use 'WPA' or 'WPA2' security.
That will prevent "sniffing" of your wireless traffic.
D-Link DIR-300... | Answered on Feb 02, 2015
For resetting up your d-link router password you have to follow these steps..
1. open your browser and type 192.168.1.0 and type user name and password
2.go to wireless settings . you can also restore d-link router settings .
3. or you may can press the reset botton on the back of your router .for more technical help contact d-link Tech Support .i hope this will help you..thanks
D-Link DIR-300... | Answered on Nov 26, 2014
Type your router's IP address -192.168.0.1- into your Web browser.
At the login screen, select "Admin" from the drop down menu and enter your admin password.
Once you access the Web configuration screen, click "Setup" in the top menu.
Select the "Wireless Settings" link on the left-hand side.
From there, click on the "Manual Wireless Connection Setup" button.
Scroll down to the field representing my "Pre-Shared Key". If you don't see it, select a security mode from the dropdown menu at the bottom of the screen first.
Type in a new password.
D-Link DIR-300... | Answered on Aug 14, 2014
Google it out.. Try the advanced search.. Or you can use this intitle:index.of DIR- 300 Wireless router driver
Jus type it like that
D-Link DIR-300... | Answered on Aug 11, 2014
remote reboot:
1) login into router
2) http://$address/sys_cfg_valid.xgi?&exeshell=submit%20REBOOT
where $address is IP address:port of your router
D-Link DIR-300... | Answered on Mar 19, 2014
wps button for printer are in the printer wifiu setup go to setup menu and serach for wifi routers once u find the router try pressing the wifi button on the router within 30 seconds
D-Link DIR-300... | Answered on Mar 15, 2014
u can reset your router to factory settings and update to the latest firmware and after that u must redo your settings that u hat in the router
D-Link DIR-300... | Answered on Nov 24, 2013
Try deleting the wireless associations on the devices which have the problems, and then re-connect the device to the router. This should solve your problem.
D-Link DIR-300... | Answered on Oct 30, 2013
Login to the router on its default IP address (sticker on the bottom) - there's an option in the settings to disable uPnP - though unless you know what you're doing, I'd recommend leaving it on.
DLink.com, go there. Support, device name, read instructions, download firmware, flash device.
D-Link DIR-300... | Answered on Oct 24, 2013
Portforward.com has a great reference for most routers including yours. Verify what you did matches the instructions on this site.
PortForward.com instructions on how to configure DLink DIR 300
http://portforward.com/english/routers/port_forwarding/Dlink/DIR-300/GameRanger.htm
If you still cannot connect, verify GameRanger is allowed through your firewall. If you are using the Windows Firewall, temporarily disable it and see if you can now connect and host a game.
Windows 7 - how to disable Windows Firewall
http://windows.microsoft.com/en-us/windows/turn-windows-firewall-on-off#turn-windows-firewall-on-off=windows-7
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/daniel_9df0c6dab34f0108
D-Link DIR-300... | Answered on Oct 03, 2013
D-Link DIR-300 Wireless Router Logo
235 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
restore d link dir 300 router factory
  • Computers & Internet
