How old is the engine? Does it have electronic ignition or points? Check the engine stop wire where it attaches to the throttle control on the engine. Make sure it is not grounding out. Has the magneto been removed? That is the Y shaped part behind the flywheel, where the spak plug wire attaches. If the mag has benn removed, it needs to be re-adjusted. The correct gap is .020 of an inch, about the thickness of a matchbook. This gap is measured between the two legs of the mag and the flywheel. I hope this helps, good luck.
