SOURCE: Danby microwave
Check if your fuse is still ok. If the fuse is gone replace and see if it is working.
SOURCE: Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
SOURCE: Danby microwave does not heat food and makes loud constant noise.
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
SOURCE: I just want to register my new microwave Danby
You can register your microwave on the link below.
https://www.danby.com/registration.php?ln=USE&
