All manuals for routers are free
all manuals are on line, all are. for sure under 10 years old or even older most.
yours is 2005 made a real relic now. 13 years old for you
and now 17 years old.
no 2 routers work the same why (settings or features all)
you did the long reset (at button) so the router is now back to day1, new in the box state
so only cure is the manual
now I will google it for you, 10 sec work
the manual is at MSI.com but is slow to navigate there,so I am lazy here is the echo of it, 182 pages deep., shocking yes but routing is complex. but basic setup is not hard.
https://www.manualslib.com/manual/360230/Msi-Rg-54g3.html
at IP address
192.168.1.254
see page 10 first, how to access the build in setting page of the router.
on PC uses chrome to access it or firefox v95 up
do not use IE1 to 11, as it has problems now.
page 10.
click OK to any security certificate error do to 17 year age.
SOURCE: MSI rg54g3 ieee802.11g vista driver
Generally you do not install a router onto a PC you connect to a router with a wire using a network adapter or wirelessly with a wireless adapter. Can you any of the following you have identify you make and model of PC, make and model of add-on adapter card? Then I may be able to assist you in determining if a driver exists for the device attached to your computer intended to communicate with the identified router.
Thanks
SOURCE: standard username and password
hello!
By default the router username is admin, and the password is also admin
SOURCE: how do i encrypt my system
Hi, I will lend a hand if I can.
There are four basic steps to set up wireless security:
1) Login to your router
2) Change the router login password/username
3) Change the network name, or SSID
4) Enable WPA encryption
As you only want encryption, I will go straight to step 4. The following is based on the manual for the MSI RG54G3.
Here are the details:
1. Login to your router.
2. Go to Setup> Wireless.
3. Select WPA-PSK - strictly speaking the correct option depends on your wireless adapter. However, this is usually a good choice to start with. You may see one or more new options pop up. Select ASCII if necessary.
4. Under ‘Pre-Share Key’ you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappynEWYeartoyou8899). It is case sensitive.
5. Note down the ‘Pre-share key’, also called the network key, carefully. You will need this to connect wirelessly. (The network key may also be called a WPA shared key, PSK, pre-shared key, passphrase, authentication key). Click ‘Save’ when finished.
When you next attempt to connect wirelessly, you are asked for the network key you've just set up. If all goes well, you can then save this and will connect automatically in future.
Hope this helps, but if it is not clear or doesn't work, please come back to Fixya. Good luck.
SOURCE: I have been given the MSI RG54G3 Router without a
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
