The noise is likely either the seal or a bearing in that order. If you are mechanically capable of working on the pump yourself then you can purchase a seal and gaskets at a pool supply store. If the bearings are bad then the motor needs to be replaced. In some cases a bearing can be replaced but usually it is more work than it is worth.
