Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
Posted on Nov 13, 2017
I have a 03 Min Kota Maxxum that doesn't run anymore. The batteries are good. The plug is good. The red arrow lights up on the top of the motor. When I put it on MOM or CON it doesn't run at all. Any suggestions on how to troubleshoot the issue? I read on line that mother board may be an issue. Thanks in advance. D
1 Related Answer
Anonymous
  • 2920 Answers
  • Posted on Sep 21, 2008
SOURCE: MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
it has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
When troll motor is switch to mom and pedal engaged motor does not run, but when switched to con it runs in this mode. this problem just started, replaced switch and problem still the same.
I'd be looking at a connection problem AFTER where the pedal connects to the unit. It doesn't take much of a "bridge" to cause an open at the chassis mount OR perhaps in the home unit itself. Since the unit runs when switched to "CON" we can eliminate a power supply issue. I'd be looking for an obvious physical problem such as a cold solder joint. Try cleaning the circuit board with silicone spray (SAFE FOR PLASTICS ONLY!!!) and see if that gives you any joy.
Hope this helps and good luck!
3helpful
My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
2helpful
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Minn Kota 55 directional problem? (night fisher)
Hi!
Here is a schematic:
Max 55
There is no LIGHTED directional indicator, but there should be an indicator nonetheless on top.
Best of luck!
Mike
8helpful
I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
2helpful
2answers
Can you wire a minn kota foot control
.....I think so ;)
Here's a schematic, complete with wiring diagram:
Maxxum 70 Bowmount
Best of luck!
Mike
2helpful
Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
What size batteries needed for minn kota 24 volt 74lb thrust
I use Red Hot Mama batteries. These have held up for longer than any other brands that I have used. These are deep cycle marine wet ones.
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
