20 Most Recent Minn Kota Maxxum 80 Freshwater Bow Mount With Us2 Questions & Answers
I was using it when all the sudden it just quit
Hey SCOTT .. Get a multimeter (to check voltage) Verify you have 24 volts coming to the front plug. Now - VERIFY that you are getting 24 volts to the switch. ..All OK..- Now to check the power switch. Disconnect the two wires on the power switch and CAREFULLY connect them by hand.. now SAFELY see if the prop will turn. If the switch is bad, bypassing it will make the prop spin! ..If the prop still does not work,, keep following the voltage.. For more help, trust these guys!: http://www.jonestrollingmotor.com/
6/12/2017 11:56:57 PM • Minn Kota Maxxum... • Answered on Jun 12, 2017
I recently bought a 2008 Triton FS 188 which has a
go to minn kota.com
2/9/2011 11:39:14 PM • Minn Kota Maxxum... • Answered on Feb 09, 2011
Ticking noise inside motor head
I dont know if this is your problem,but I just took mine apart and the brushs were stuck,cleaned and put back.works like a new on.
11/11/2009 8:22:39 PM • Minn Kota Maxxum... • Answered on Nov 11, 2009
We have a Minn Kota riptide 55. Serial WWAI12730357. Used once when new and has been sitting since. We need a manual.How do we go about getting same.
Hi. Based on the serial number provided, your Riptide PowerDrive would be a 2008 Weedless Wedge model. You can download the product manual at the following link: https://johnsonoutdoors.widen.net/content/myx2vf5heb/pdf/min_productmanual_rtsp-55-om.pdf
1/15/2024 11:14:38 PM • Minn Kota... • Answered on Jan 15, 2024
I left my minn Kota I pilot turn on will this be harmfull
Hi. I believe you are referring to a Minn Kota with i-Pilot GPS? If you forget to turn the power button off and the motor was not running (meaning the prop was not turning), your motor should be fine. Ultimately, if left on for long enough, it will drain the batteries and eventually turn off. This is not harmful for the motor. For safety reasons (yourself and others), it's always best to disconnect the motor from the power source when not in use.
1/14/2024 10:12:39 PM • Minn Kota... • Answered on Jan 14, 2024
Minn Kota DeckHand 18 won't run
Did you check the breaker and fuse. The strain of a rope foul would trip the breaker. Page 18 shows breaker in circuit for the DH15 - DH25 https://productimageserver.com/literature/ownersManual/36957OM.pdf
Fuse or circuit protector ' Boating Forum
iBoats https://forums.iboats.com > threads > fuse-or-circuit-pr... Mar 9, 2021 - I just purchased 2 Minn Kota DeckHand 40 anchor winches. They have built in circuit breakers, but should I also run fuses to them as well? You would need to strip it and test the motor. You can still get parts by the look of it. https://www.google.com/search?q=Minn+Kota+DeckHand+18 ..
7/31/2023 11:27:48 PM • Minn Kota... • Answered on Jul 31, 2023
I have a Minn Kota Traxxis 80, the proble is the extending handle free slides and is an irritation. Is ther a way to tighten the sliding extension.
Yes, there is a way to tighten the sliding extension on the Minn Kota Traxxis 80 handle. Here are the steps to follow:
  1. Locate the set screw: Look for a small set screw on the side of the handle where the sliding extension meets the stationary part of the handle. This screw is typically located on the underside of the handle and may require a small tool to access.
  2. Tighten the set screw: Using the appropriate tool, tighten the set screw by turning it clockwise. This will secure the sliding extension in place.
  3. Test the handle: After tightening the set screw, test the handle to make sure it is secure and does not slide freely. If necessary, adjust the set screw again until the handle is secure.
  4. Reassemble the handle: Once the sliding extension is tightened, reassemble the handle by replacing any covers or trim pieces that were removed to access the set screw.
Remember to use caution when working with small screws and tools, and to follow any safety guidelines provided by the manufacturer.
2/24/2023 1:55:43 PM • Minn Kota... • Answered on Feb 24, 2023
Minn Kota Powerdrive V2 i-Pilot Bowmount Trolling Motor was working well, but in one moment not responding direction, to left or right.
Have you tried Resetting it? for PowerDrive models, disconnect then reconnect power.
2/21/2023 7:03:40 PM • Minn Kota... • Answered on Feb 21, 2023
I have a Minn Kota 315D 3 bank charger. When I plug it in to my electrical outlet only bank 1 shows a solid yellow light. I am not getting power to bank 2 and 3.
A solid yellow light on Bank 1 of your Minn Kota 315D 3 bank charger indicates that the charger is in "float" mode, which means it is maintaining the battery's charge at a safe level. It sounds like there may be an issue with the connections or wiring for Banks 2 and 3, preventing them from receiving power. Here are a few things you can try:
  • Check the connections between the charger and the batteries for Banks 2 and 3 to ensure they are tight and secure.
  • Ensure that the circuit breaker for the charger is not tripped.
  • Check the wiring for Banks 2 and 3 for any visible damage or corrosion.
  • Ensure that the batteries for Banks 2 and 3 are not in a low state of charge or are not faulty.
  • Try to reset the charger by unplugging it from the power source and plug it back in after a few minutes.
1/20/2023 10:20:52 AM • Minn Kota... • Answered on Jan 20, 2023
I have a Minn Kota 35c serial #42064 and need a new propeller, does anyone know where one can be found?
manufacturer--marine shops --online
9/8/2021 6:40:48 PM • Minn Kota... • Answered on Sep 08, 2021
Minn Kota Riptide Co Pilot is losing speed. Foot pedal is at 10 & speed is a constant slow. HELP
go see your local dealer there are speed coils internally that burn out and I'll guarente you that you can not fix it yourself , I did for 13 years
5/22/2021 5:49:32 PM • Minn Kota... • Answered on May 22, 2021
Minn kota ultrerra is stuck in stow and will not deploy. How do I reset or troubleshoot?
In the unlikely event Ulterra will not trim or stow, the following procedure will reset the motor and restore functionality:
  1. Press and hold the POWER button located at the mounting base to turn power off (green LED light will turn off).
  2. Press the POWER button until the green LED light illuminates.
  3. Wait 3 seconds.
https://www.minnkotamotors.com/support/faqs/there-manual-over-ride-function-case-power-loss-or-if-auto-stow-and-deploy-does-not
5/6/2020 2:45:46 PM • Minn Kota... • Answered on May 06, 2020
Where can I get a wiring diagram for a Minn-Kota 4 hp trolling motor
you could try calling Minkota or one of their repair centers. They are good to work with.
10/26/2019 12:44:10 AM • Minn Kota... • Answered on Oct 26, 2019
I have a minn Kota riptide 112 pd thrust The hand piece is saying motor error. It will trim about 4 inches and will go back down the same. Is there a way to reboot the motor error
Press and hold the (Power) button located at the handle or mounting base to turn power off (green LED light will turn off). Press the POWER button until the green LED light illuminates. Wait 3 seconds. should be goo to go. Wallyd"
10/2/2019 10:45:07 PM • Minn Kota... • Answered on Oct 02, 2019
Minn Kota Maxxum 80 Freshwater Bow Mount With Us2 Logo
5 questions posted
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
View Most Popular
Minn Kota Boating
  • Minn Kota Boating
Most Popular Question
using when all sudden just quit
  • Boating
