Konica Minolta magicolor 5430 DL Laser Printer Logo
Posted on Oct 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fatal Error 0300H
My printer was working fine, and suddenly no longer works and states FATAL ERROR CODE: 0300H. Can you advise what this means and what I can do about it. I have turned off and on, checked for paper jams, checked cartridges in okay. At first the printer made a noise when I turned it back on, now nothing happens at all.
Thank you.
  • imagerybygra Oct 31, 2008
    When I turn on the printer, it starts to make a high pitch whining noise then stops and has an error code 0300H.
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Apr 28, 2019
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1914013
Points
11960
Model number would help
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on Jun 19, 2008
SOURCE: Konica Magicolor 5430 DL Fatal Error Code: 0300H
0300H: Polygon Motor malfunction
try restart if not helping then there can be problem with ph unit or PWB-A board
myob247
Georgia B
  • 1342 Answers
  • Posted on Jun 26, 2008
SOURCE: HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Anonymous
  • Posted on May 12, 2009
SOURCE: hp officejet j5780 Constant paper jam
clean feed rollers
Anonymous
  • 214 Answers
  • Posted on May 16, 2009
SOURCE: Printer states System Error Clear paper jam but no paper is there
If you did have a jam and did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it.
Anonymous
  • 24 Answers
  • Posted on Feb 24, 2010
SOURCE: says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
1helpful
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "[email protected]" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Fatal error 708
1helpful
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
Can't download iTunes, IE 8, HP Printer...Fatal Error MSI Scan is the usual statement, although I've gotten numbered failures too. But Fatal Error is the main one.
Hey
The SCAN.MSI that comes up about your HP printer, that is located on the CD in a special folder.
It would be best for you to completely uninstall all HP programs from the computer related to the printer.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
unplug the printer first
use the free(ware) version. Download the program, start it, go to the uninstall programs part, find the HP related items and uninstall, Use medium setting and delete all files and items it finds, just click on select all and then delete.
When that is done restart the computer, then use the CD or I'll direct you to the full feature download to reinstall it.
I've delt with this scan.msi issue quite a few times here and I know how to solve it. If this doesn't work for whatever reason you would have to go to the cd (right click, open) and find the scan.msi file, when the error comes up asking for the scan file, direct it there (Exactly to the file in the cd, it may be hidden inside a few folders) and it should solve that one.
My DFX-5000+ WILL ALL OF A SUDDEN GO DEAD FOR ABOUT 10-25 MINUTES OR SOMETIMES LONGER WHY??
Sometimes these machines will overheat or have fatal errors or general errors. Unplug the printer from the power source for no less than 10 minutes, The plug the power cable back into the printer and turn it back on. This should solve this issue.
Printer fails to print - error code -50
From System Preferences / Printers, delete the printer completely.
If you have the driver installer for the driver you are using, re-launch it and choose the "uninstall" option. If not, you will have to rip out a lot of code by hand -- you will have to search HP's website for the page on how to manually remove traces of old Mac HP drivers.
Download the latest driver for your printer from the HP website. Install if carefully.
After rebooting, go to System Preferences / Printers and re-define the printer. Make sure you use the HP driver, not any of the generic drivers.
This ought to clear the problem.
Error Code 155: Fatal Error
Looks like a fuser error-
re-seat fuser
check for paper scraps, etc in fuser and printer.
Service call
155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Reinstall the fuser after its
connection connector is cleaned
if error still exists-
Turn on the power supply again
Replace M32 board after check
the cable connection.
2answers
Kodak Easyshare 5300, fatal error 3812
That's an error with the ink. Try updating the firmware on the printer. Here is the link to the latest firmware from the Kodak website.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
3helpful
C5200 printer
177 - Replace fuser
1helpful
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
