Tip & How-To about Rangemaster 110 (Gas) Kitchen Range
Cooker jets blocked
If gas jets get blocked sock in hot water and steradent tablets.
Rangemaster 110 (Gas) Kitchen Range Logo
I have a household LPG 16 H instant hot water which is not igniting but I can hear it sparking, there is plenty of water , perhaps the water pressure is too strong?
check that the pilot light jet is not blocked or that the jet for the main ring is not blocked . Water pressure has nothing to do with the lighting only the temperature of the water coming out . check that you have gas and that the line hasn't been turned off.
Not hot enough
Check that the gas jet is not partially blocked limiting the amount of gas out. To up size my bbq to a hotter flame I used oxy welding set tip drills and gently opened up a size. worked a treat and cooked quicker. maybe you can get next size jets for your problem. check that the regulator is not restricting the gas flow.
eco steam master 2-1
One more thing to try assuming its blocked tubes/jets the problem 1) a strong steradent solution or any de-calcifying solution. Again, leave to soak for a couple of days.
Jun 03, 2012 • Irons
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
