20 Most Recent
Keurig B150 Office Brewing System Questions & Answers
Keurig k155 touch screen blank
If the touch screen of your Keurig K155 brewer is blank, here are some steps you can try to troubleshoot the issue:
- Check the power supply: Make sure the brewer is properly plugged in and the outlet is working. Try unplugging and plugging the brewer back in to reset it.
- Clean the touch screen: Use a soft, damp cloth to clean the touch screen, as dirt and debris can interfere with its function.
- Perform a hard reset: Unplug the brewer from the power source and remove the water reservoir. Press and hold the power button for 5 seconds, then release it. Wait for 2 minutes, then plug the brewer back in and turn it on. Reattach the water reservoir and try using the touch screen again.
- Contact customer support: If none of the above steps work, you may need to contact Keurig customer support for further assistance. They may be able to offer additional troubleshooting steps or provide repair options if needed.
