20 Most Recent Maxtor OneTouch A01B080 80 GB Hard Drive Questions & Answers
I do not see the disk on window
try searching for "create and format hard disk partitions" Open, and your disk is probably shown there as needing to be initialized or formatted. I suspect some compatibility issues are keeping Windows from seeing it. I have found that 2 or 3 years is the maximum time I use an external drive, as they go bad. I would try the drive in another computer, and if it sees it, copy all your data to a flash drive or a folder on that computer. Then format the drive, put your data back on and see if it is recognized on your computer. If not, go back to "create and format hard disk partitions" (after making sure you still have a copy of your data somewhere) and initialize or format or whatever it tells you to do. Then windows should recognize it, and you can put your data back on. But in the meantime I would be pricing new external drives.
12/1/2017 3:42:03 PM • Maxtor OneTouch... • Answered on Dec 01, 2017
Computer not recognizing my Maxtor hard drive
Andrew, That Maxtor drive sounds like it has finally died on you and being just an 80 gig drive means its really old. The systems failure to read the drive as your booting up is what's causing the long boot delay as the system will see the controller board of the drive, but your spindle motor on that drive is most likely dead and there fore you will not be able to access or read any of your data stored on that drive. Hope you had backups of important files.
4/16/2017 12:53:55 AM • Maxtor OneTouch... • Answered on Apr 16, 2017
0answers
My Mac OS X doesn't recognize my Maxtor One Touch
Try unplugging both the power and data cables from both the computer and the hard drive. Let the hard drive spin down. Plug the cables back in. It should become visible with no loss of files.
11/8/2009 11:31:18 PM • Maxtor OneTouch... • Answered on Nov 08, 2009
2answers
I lost the power supply and would like to know
Power Requirements
AC Input Voltage: 100–240 VAC
Input Frequency: 47–63 Hz AC
here is a link to the manual : http://www.seagate.com/staticfiles/maxtor/en_us/documentation/data_sheets/onetouch_data_sheet.pdf
10/30/2009 1:36:00 AM • Maxtor OneTouch... • Answered on Oct 30, 2009
My Maxtor Hd Wont show up anywhere in my laptop when i plug it in
it should still detect even though your using vista does your bios setting have usb2 enabled?? otherwise try a different usb port
6/18/2009 8:53:58 AM • Maxtor OneTouch... • Answered on Jun 18, 2009
I just bought and Avertech 3.5 SATA HDD and need
Try to restart your computer  and let the computer boot and detect that device you presently inserted.
6/17/2009 3:41:14 AM • Maxtor OneTouch... • Answered on Jun 17, 2009
Maxtor Portable External 250 gb not accissible because of error : "Error in inpage operation"
The inpage error is generally the sign of a failing drive and usually the one you are clicking on when it pops up. It is indicative of recent or pending failure of the drive. This means it may not be accessible through normal means, however they can sometimes be repaired(cases such as having been powered down without ejecting).
If your's was unplugged while copying or before using the windows eject function, this is likely the case. If the drive letter is X open your start menu then:
XP/2000 Click Run, then type CHKDSK X: /F then click OK, restart the computer and let it run the consistency check.
Vista: Click into the searchbar and type CMD then hit enter, when the black and white command prompt window comes up type in CHKDSK X: /F then hit enter. Type EXIT then hit enter. Restart the computer and let it run the consistency check.
Either way, if it works and the drive is back copy the important files onto the computer as you should always have them in 2 places. If it does not work you will likely need the help of a pro getting the files back.
Remember, Backup drives are for keeping backups, in the future always keep everything in at east two places. Although I love my friendly neighborhood data recovery specialists, life is cheaper and less frustrating when we don't need their help.
Chris
5/24/2009 12:49:53 PM • Maxtor OneTouch... • Answered on May 24, 2009
4answers
External Hard Drive
Couple of questions first: -What operating system was running on the new and old PC? -Is the old PC still running and available? Once you answer these we?ll start work.
11/8/2008 3:31:19 PM • Maxtor OneTouch... • Answered on Nov 08, 2008
Maxtor External Hard Drive Trouble
This is a duplicate post, click on the link below to view the active post. http://www.fixya.com/support/t136321-external_hard_drive
11/2/2008 4:28:26 PM • Maxtor OneTouch... • Answered on Nov 02, 2008
2answers
Maxtor formatting
i have a maxtor my computer crashed and i lost my disk how do i get my pictures back
10/20/2008 12:51:25 PM • Maxtor OneTouch... • Answered on Oct 20, 2008
Bought NEW MAXTOR ONETOUCH III (No software included???)
Tell Rey Barcelo that the Installation software is on the hard disk
inside of his Maxtor OT Mini III 80 GB. There is no physical CD.
It's all on the hard drive inside of the device. I had my computer
expert look at it and now the device is working normally.
A lot of Kudos to you for steering me in that direction.
8/19/2008 12:19:19 AM • Maxtor OneTouch... • Answered on Aug 19, 2008
External Hard Drive
3/4/2007 9:45:06 PM • Maxtor OneTouch... • Answered on Mar 04, 2007
External Hard Drive
3/4/2007 9:44:39 PM • Maxtor OneTouch... • Answered on Mar 04, 2007
Maxtor OneTouch A01B080 80 GB Hard Drive Logo
Popular Tags
20 questions posted
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Maxtor Computers & Internet
Most Popular Question
bought new maxtor onetouch iii no
  • Computers & Internet
