20 Most Recent
Milwaukee Tool 3/8" 12 V Cordless Variable - Speed Drill Questions & Answers
Slipping clutch on low switch with Milwaukee 2601-20
this tool has a 5 year limited warranty so I would try and have repaired under warranty. I looked at a breakdown and it doesn't specify how the chuck is on but I would to think it is threaded. the clutch is an assembly and there are no replacements parts other than the assembly available. Let me know if you need more assistance.
My M18 cordless drill overheated and smoke came pouring out
Yes this does have brushes, they are mounted on plastic plate that has to be soldered onto the switch. That noise might be the vanes that have broken off the main rotor. If you open it up you will be able to see. Yes they can be repaired but check with the milwaukee agent for cost. Some times it is more cost effective to buy a body only. Brush card is cheap about nine pound inc vat.
I want to repair cable on a milwaukee hammer drill 5392-1
If you mean the cord you can find the part number by going to milwaukeetool.com and you will need the serial number for the correct one. Or you can also go to ereplacementparts.com. You will need to solder the wire ends to push into the swiitch. To release the old cord straighten one leg of a paper clip and insert next to the wire and gently pull out the old cord. UNPLUG tool first and make note of where the wires came from. The Milwaukee site also has a wiring diagram that you can download. Let me know if you need more assistance.
No! I merely want a Operator's Manual for the
go to milwaukeetool.com and you will need the model number along with the serial number but you can download the manuals you need from there. Let me know if you need more assistance.
