20 Most Recent Acer Aspire 5920 AS5920 Notebook Questions & Answers
2answers
Acer aspire 5349 wont play dvds only cd
Try installing a new software program to play your DVDs. Also look for updated dvd player drivers from Acer site.
1/15/2015 3:38:43 AM • Acer Aspire 5920... • Answered on Jan 15, 2015
Base system driver aspire 7720G update
look for driverpack solutions 13 via google burn the iso ,start the system and put in the cd this will then scan your system and update your missing drivers.
6/12/2014 7:55:22 PM • Acer Aspire 5920... • Answered on Jun 12, 2014
0answers
Blue scree
Be the first to answer 4/23/2014 11:46:39 AM • Acer Aspire 5920... • Posted on Apr 23, 2014Be the first to answer
I'm using acer aspire 5920
If you show a Blue Screen, you have more problems then it not being able to turn off/shut down?? I would back out the battery so as to stop power from getting to it, AFTER you have it unplugged..then push battery back into to engage, plug the AC cord back into the PC. turn it back on and IF you still show a BLUE screen, you will need a tech to check it further...GOOD LUCK...
8/2/2013 6:43:40 PM • Acer Aspire 5920... • Answered on Aug 02, 2013
2answers
I have an att.net account, yahoo mail comes up
are you with BT by any chance?
8/2/2013 6:32:26 PM • Acer Aspire 5920... • Answered on Aug 02, 2013
How will i make my 2go star boost fast
if you are looking for a faster windows boot and operation your best bet would be to upgrade your harddrive to SSD(Solid state drive) super fast, windows boots in a matter of seconds...but give this site a read...http://howto.cnet.com/8301-11310_39-57363586-285/how-to-start-windows-7-faster/success
6/19/2012 11:46:48 AM • Acer Aspire 5920... • Answered on Jun 19, 2012
How can i erase hdd
Please try these steps:
1. Turn on the computer, while it's loading, tap the F2 key to access BIOS. You may also try F10 if F2 is not working. 2. Go to Security, enter the password then change password. Do not type anything on the new password just press enter. 3. Save the changes.
9/15/2011 4:45:06 AM • Acer Aspire 5920... • Answered on Sep 15, 2011
I don't know bios password
The bios master password you need is one of the passwords below: zwbpwso rc0t1fw o42pe25
Thanks to my friends at http://www.unlockbiosrecovery.com/ for generating the above passwords.
9/12/2011 3:47:37 AM • Acer Aspire 5920... • Answered on Sep 12, 2011
How do I replace the
After shutting down, removing the power cord and the battery, turn the laptop upside down. About two-thirds of the back of the case is one removable lid. The lid retains its 9 screws. Remove the screws.
The RAM sticks are stacked square in the middle.
The RAMs are held by 2 clasps. Gently pull them outwards and the RAM would pop up to a 45 degree angle and you can pull them out easily. Note the cut at the bottom part of the RAM and place/ slide in the New RAMs accordingly and just press them to snap them in place.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
7/19/2011 9:14:49 AM • Acer Aspire 5920... • Answered on Jul 19, 2011
Acer aspire will boot up
I am quite sure the operating system is corrupted. Just install fresh operating system.
But still you mention, that it is booting up but it is just blank screen or shut down.
Try to press F8 key once when start up boot to go to ADVANCE BOOTING OPTION. If you are lucky, it will load this option and choose LAST KNOW GOOD CONFIGURATION. or if you have the Operatins system installer CD, put inside the CDROM and repair the operating system.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
5/12/2011 11:41:29 AM • Acer Aspire 5920... • Answered on May 12, 2011
2answers
I recently returned from Afghanistan
One time i had the same problem, i went searching for answers but all in vain, this is exactly a sata hard drive, even from manufacturers of Hard disks they can't give a solution or support for this problem, this password uses a complicated encryption method that's is impossible to break. So my dear friend, try and recall the password or you have to replace the hard drive.
1/7/2011 7:23:28 PM • Acer Aspire 5920... • Answered on Jan 07, 2011
Forgotten password after not using computer for a
Is this a bios password or a windows password? You can tried going on safemode by presing F8 before you turn lapton on.Press F8 for a few time.
12/11/2010 7:46:20 PM • Acer Aspire 5920... • Answered on Dec 11, 2010
Hi der! i own an
Get a paperclip and bend it out so its in one long pin, put that in the tiny hole on the front of the cd drive and move it gently forward and back, this should release the drive so it opens and hopefully its just a case of a cd jammed in there which will free it up once you remove it.
If not let me know and we'll look further :)
10/29/2010 1:52:41 PM • Acer Aspire 5920... • Answered on Oct 29, 2010
2answers
My acer 5920 screen flickers untill I tap it
windows might have recently updated the driver and it might have changed the settings. right click on your desktop click personlise then display settings try changing the resolutions and the refresh rate to 60hz if that doesnt work download the driver of your graphics card from your manufactures website and install it over the old driver and do the same for the monitor. Let me know how you get on!
3/5/2010 11:09:31 AM • Acer Aspire 5920... • Answered on Mar 05, 2010
3answers
It flickers and is brand new it is an acer model 5534
return and get a new one
12/29/2009 9:06:11 PM • Acer Aspire 5920... • Answered on Dec 29, 2009
Acer Aspire 5920 AS5920 Notebook Logo
70 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
just given acer5920 yo reset
  • Computers & Internet
