20 Most Recent
Dean Evo Xm Electric Guitar Questions & Answers
I dont know how to
It is rare that wires would be faulty. Soldering can be, but not the wires usually.<br />
<br />
Common problems are broken jacks or pots that are broken or shorting to the paint in the cavity.<br />
<br />
If you have things unwired now, the best thing is to find an appropriate circuit here and wire it like that:<br />
<br />
<a href="http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/">http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/</a>
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
