20 Most Recent Dean Evo Xm Electric Guitar Natural Mahogany Questions & Answers
Ground wire is not attached
okay. the ground needs to travel through all your components.you have the -input jack, - vol. & tone pots, the -switch & all - pick ups. All should meet at the body ground. Usually there is a wire that comes from the saddle, through the guitar, and enters somewhere in the access in back. (remove the plate that cover your vol. and tone pots). Good Luck
4/19/2014 6:56:19 AM • Dean Evo Xm... • Answered on Apr 19, 2014
I did not get a
I don't know precisely, but since it is a dual humbucker and only has 1 switch and 2 knos, the knob nearest the neck is probably the volume, and the other is the tone. The switch should select which pickup is in use, towards the neck for the neck or rythym pickup, and the other way for the bridge or lead pickup. If it has a centre click position, that will be both pickups on together. If one of the knobs has a pull position, that will likely be a single coil switch for the lead pickup.
5/4/2011 3:47:27 AM • Dean Evo Xm... • Answered on May 04, 2011
Is there any way to make guitar pickups hotter
Lay guitar electric guitar flat (pickups facing the ceiling) then heat up the pickups for a minute or two
1/4/2024 10:20:24 AM • Dean Music • Answered on Jan 04, 2024
2answers
Need to know if my guitar is USA or othercountry !!
Contact Dean customer service to get the best info. Here's the link- CUSTOMER SERVICE INSTRUMENT REPAIR
12/22/2018 1:07:49 AM • Dean Music • Answered on Dec 22, 2018
Where can I find part 2 of an audio book, it is not in my library.
Try to download it again
11/21/2017 4:35:40 AM • Dean Music • Answered on Nov 21, 2017
What year was it made in and how much was it ?
www.deanguitars.com
6/28/2015 3:45:13 PM • Dean Music • Answered on Jun 28, 2015
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
Dean Evo Xm Electric Guitar Natural Mahogany Logo
3 questions posted
Top Dean Music Experts
ADMIN Eric
ADMIN Eric
Tahir Hussain
Tahir Hussain
umar waheed
Are you a Dean Music Expert? Answer questions, earn points and help others
View Most Popular
Dean Music
  • Dean Music
Most Popular Question
ground wire not attached
  • Music
