20 Most Recent
GE Spacemaker JVM1750 Microwave Oven Questions & Answers
Replace inside light bulb
gonna needa open it up theres about 6 screws holding the covere and it like a small light blub u can uncrew it or if not it has a has a clip u pull off and are able to change it
Reading F3 and workes by it self
MAKE THIS TEST AND FIX IT. God bless you
- Interlock switchIf your
microwave is turning itself on, the first thing to check is the
interlock switch. This is usually the first thing to malfunction that
could cause this issue. If the interlock switch is bad then it will need
to be replaced.
- Main control boardIf
your microwave is turning itself on and the interlock switch is still
working, the probable cause is the main control board. If the control
board is defective it will need to be replaced.
No power
Hello there and welcome to fixya This a fairly common issue with these microwaves Normally what the problems turns out being that the fuse that sits on the controle board inside So what you are going to have to do is first remove the outer shell this is done by removing the screws that are on the edge of the unit along the back then remove the screws on the sides then all you have to do is to slide the cover back towards the rear abnout 1/4 inch then the cover should lift off ok?the fuse sites on the right side on a electronic board on the right side as you look at he microwave from the front simply remove the fuse and replace it WITH THE EXACT SAME FUSE THIS IS VERY IMPORTANT then test the microwave it it now works great all u have to do is to put the cover back on and you are done okHowever if it does not work then you will have to investigate the power inverter and have it tested this part can be expensive (just to let you know ) ok?Please keep me informed on how this is going post me a comment ok?Best regards Mike
I have a new JVM1750 just installed yesterday.
That is your stirrer cover.Any arcing there is usually due to grease or food particles, so on a new oven that would be as mystery.But any time you get arcing under it, it has to be removed and cleaned.
I have a new
Inside there's a little door switch there's 3 of them they have to be in sequence You can adjust them with a screwdriver phillips
I have the GE JVM2070BH02
Check the door switches with ohm meter and make sure they are working properly, the door switch has been known to disable the keypad when faulty.
