20 Most Recent
Presto 2811 Coffee Maker Questions & Answers
Presto 2811 cold and weak coffee
How old is the coffeemaker? Is it used every day? If it is within the one year warranty it can be replaced if you ship it to Presto. Or you can call for more information at 800-877-0441 which is customer service.
I have a WMF Presto coffee machine and when I switch it on it comes up with WMF-AG V-Bootmanager 9,0 USB 1.1 on the screen and cannot do anything at all with the machine
The message you are seeing on your WMF Presto coffee machine suggests that it is stuck in the boot process and is unable to start up properly. This could be caused by a software or hardware issue.
Here are some steps you can try to troubleshoot the issue:
- Check the power supply: Make sure that the machine is properly plugged into an electrical outlet and that the outlet is functioning correctly. If the outlet is not working, try plugging the machine into a different outlet.
- Restart the machine: Try turning the machine off and on again to see if it resolves the issue. If this doesn't work, try unplugging the machine from the power source, wait for a few seconds, and then plug it back in.
- Check the USB port: The message you are seeing on the screen suggests that the machine is looking for a USB device. Check to make sure that there is no USB device plugged into the machine. If there is, remove it and try restarting the machine.
- Contact the manufacturer: If none of these steps work, it may be a hardware issue. Contact the manufacturer or a qualified technician to diagnose and fix the issue.
It's important to note that attempting to fix the machine yourself may void the warranty or cause further damage.
Electric perculator plug
The common peoblem with these types of heating devices (coffee makers etc) is that the female portion of the plug gets hot over time and becomes loose. As it gets looser in heats up because of the bad electrical connection. Your only option is to buy another plug and cord. Attempting to repair is not feasible, and can actually have negative effects, like causing a fire or a electrical spark. You can find a lot of replacement parts on line by goggling your model number. Good luck to you....
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
De'Longhi PrimaDonna Soul Coffee Maker not making milk foam.
The milk delivery tube is very narrow bore and in my experience you will find the tube is blocked with congealed milk solids even if you clean then regularly. You need an enzyme milk cleaner like Rinza and even with that you need to manually massage the tubes or remove the blockages. The service engineers just replace them.
