20 Most Recent
EA - Electronic Arts Need for Speed : Most Wanted Questions & Answers
I m facing an error
open up your console and and expose it to sunlight for couple of hours, then repackage back and put it on...
Nfs problem
just check if it is clean from the back side.
I dont have they code for need for speed most
What code do you need?
CD keys aren't the same, they're all different for each individual CD - that's kind of the point, to prevent people from downloading them off the internet without purchasing them.
NFS Most Wanted Not Working On Vista...........
Change the compatibility mode to Xp SP2
go to the program files and select the NFS folder right click on the exe file and change compatibility to WIndows XP sp2 it will fix
If not , then you dont have enuff graphic memory , u must disable the AERO THEME from vista and try to play
When i am trying to open a window opens and said
if you are trying to run NFS MW then you also have to install the patch .. also read the instructions
Download it from here
http://games.softpedia.com/get/Patch/Need-for-Speed-Most-Wanted-Patch.shtml
Problem with nfs mw
this usually happens when u have less memory available on your RAM or your Graohics card.
Try upgrading ur GFX card or RAM or Both.
When i faced this peroblem, it helped me tons.
