20 Most Recent Jl Audio 300/4 Car Audio Amplifier Questions & Answers
300/4-has blown the right front
Internal amp short on that channel. Repair or replace.
10/11/2017 8:35:59 PM • Jl Audio 300/4... • Answered on Oct 11, 2017
0answers
Trying To self Repair SoundStorm 700.2, Replaced Parts and still having problems
The power transistors are shorted out and must be replaced. If you contact JL they will fix it for a flat rate. That amp is well worth it.
9/4/2013 10:39:33 AM • Jl Audio 300/4... • Answered on Sep 04, 2013
2answers
The light yellow is on what hapen whit my ampli
Depending on what light it is. It could be your ohm light, if it is your ohm light then you have something wired incorrectly. If it is another light, it could either be a power problem or it could be that your amp is damaged.If you would like, you may e-mail me and u can let me know which light is on. It SHOULD say right next to the light; which light is on. E-mail me at [email protected] and I will respond to you as soon as i recieve it.
3/8/2013 3:32:28 PM • Jl Audio 300/4... • Answered on Mar 08, 2013
0answers
Is there a fuse in the amp
No. JL is one if not the only manufacturer that does not fuse there amps.
2/18/2013 4:33:33 AM • Jl Audio 300/4... • Answered on Feb 18, 2013
Low ohm light on with no speakers connect??
This can happen if the amp has an internal fault such as a shorted output transistor.
12/18/2012 10:00:17 PM • Jl Audio 300/4... • Answered on Dec 18, 2012
0answers
Yollew indicator light keeps coming on when i hook my amp up why is this happening
Do you get the yellow light with or without speakers and rca's connected?
8/13/2012 12:30:55 AM • Jl Audio 300/4... • Answered on Aug 13, 2012
I recently got a JL
Does it only happen on that channel. It is a 4 channel amp so make sure the other channels are working. It sounds like an RCA input prob. Try the sub on the other channel. if it works then it would be your RCA input needs resoldered.
9/8/2011 4:29:07 AM • Jl Audio 300/4... • Answered on Sep 08, 2011
Jl audio amp blink low
Had the same problem once from a very poor ground connection.
showed 12V across multimeter, but could not deliver any real power across the connection due to poor grounding.
check it.
5/9/2011 1:16:34 PM • Jl Audio 300/4... • Answered on May 09, 2011
ENGINE NOISE COMING OUT THRU
check how secure your earth strap is for the amp, mabye try thicker cable, you can get interference suppressors as well which may help and are cheap.
5/3/2011 1:40:12 PM • Jl Audio 300/4... • Answered on May 03, 2011
0answers
I accidentally wired the 12v
Hi
It look like you burned the power supply in the amp if the fuse is ok
there is a circuit that protect the amp and its possible that it burned
this should not be too expensive to be fixed
[email protected]
Jack
10/19/2010 3:46:08 AM • Jl Audio 300/4... • Answered on Oct 19, 2010
Uhm need help i really dont know how to unscrew
Depending on the amplifier it has an allen key that fits the input and the speaker wires. Any hardware store will have the tool that will fit. Most of them will allow you to take it outside and test it on your amp to make sure it fits.
8/8/2010 11:13:23 PM • Jl Audio 300/4... • Answered on Aug 08, 2010
Jl Audio 300/4 Car Audio Amplifier Logo
50 questions posted
Top Jl Audio Car Audio & Video Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jl Audio Car Audio & Video
Most Popular Question
lost left side channel jl300 4
  • Car Audio & Video
