20 Most Recent
Samsung Wireless Headset for Bluetooth-Enabled Cell Phones - Gray Questions & Answers
Wep500
0000 is the default pin.
Samsung Glyde switched to nam2
Follows these simple instructions and ur phone will be unlocked in no time! AT HOME SCREEN, SLIDE OPEN, TYPE IN (#43574357*), TAP SYSTEM INFO, THE CODE IS THE LAST FOR DIGITS OF THE "MDN".
Install bluetooth
utstatcome does not have bluetooth that trasfer data it only support the headset
Connect to phone
Well... i think you need to specify a little. just write down if its bluetooth or if its some other connections...
How to pair moto 700 with samsung delve
moto -700s the vain of my existance. my experiance with this troublesome unit is with the boom mike closed hold call button down till light turns purple, quickly pull mike down and while still purple ( thats discovery mode) pair it with phone and if it askes for a pass key its 0000 ,and 1234 is backup key code. hope you only have 1 of these. i have 7. but they sure are pretty huh? good luck
Need a users manual for my wep 500
Here is where you can go to download a copy of the WEP 500 Quick Start Guide. Hope this helps.
http://support.sprint.com/resources%5CSamsung_WEP500_Pairing_Guide.pdf?z=z&navtypeid=1&pagetypeid=7&prevPageIndex=9&lid=y
MY LG TONE HBS-730 stuck on incorrect pin
i have samsung mobile
Here are some steps you can try:
Reset the Headset:
Turn off the headset.
Press and hold the REW (rewind) button and the PLAY/PAUSE/STOP button simultaneously for about 5 seconds until the LED indicator flashes purple.
The headset will reset, and you can try pairing it again.
Pairing with Samsung Mobile:
Make sure your Samsung mobile's Bluetooth is turned on.
Slide the power switch on the LG HBS-730 to the "ON" position.
The LED indicator on the headset will be solid blue, indicating it's in pairing mode.
On your Samsung mobile, go to the Bluetooth settings and search for new devices.
Select "LG HBS-730" from the list of devices.
If prompted for a passcode, enter "0000" (four zeros).
Once paired, you'll hear "Your headset paired."
Check Battery Level:
Press and hold the VOLUME DOWN button for 1 second to check the battery status. The audible alert will indicate the battery level (high, medium, or low).
Charge the Headset:
Connect the charger to the headset. While charging, the LED indicator will show a solid red light.
When charging is complete, the LED indicator will turn off.
Remember that the headset will automatically turn off if not paired within 3 minutes.
If these steps don't resolve the issue, refer to the HBS-730 User Manual for more detailed instructions.
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
