20 Most Recent Alpine New Original RUE-4151 Remote Control Questions & Answers
0answers
My setting button on my alpine navi ine-z928hd is blacked out and won't let me access it. I unplugged it for a couple hours and tried the reset button, but no change. And there's not a remote.
It sounds like you're having a problem with your Alpine Navi INE-Z928HD. I suggest that you first try to download and install the latest firmware update for your device. If that doesn't resolve the issue, then you may need to contact Alpine's technical support team for further assistance.
2/1/2023 8:48:32 PM • Alpine Televison... • Answered on Feb 01, 2023
I have a Alpine RUE-4170 and I need the circuit diagram.
Remote controls don't have manuals. They have marked button and your press the buttons. The Audio unit it connects to does have manuals. The RUE-4190 does have a manual. https://www.google.com/search?q=Alpine+RUE-4170+manual No wiring diagram exists. Take it to an electronics technician and they can test the components. Put new batteries in it and try this test. Using the front facing camera of your smartphone, face the infra red sensor of the remote at the camera lens and press an button on the remote. If the remote is working, you will see a red light flash. It only works on the front facing camera. https://www.google.com/search?q=alpine+rue-4170+wiring+diagram&rlz=1C1QJDB_enCA643CA644&sxsrf=APq-WBvsCF7rVQJGDKlUijClaw-rOK5B7w:1645914655217&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjr3OrytZ72AhVBHzQIHRyWDucQ_AUoAnoECAEQBA&biw=1920&bih=937&dpr=1 ..
2/28/2022 2:17:43 PM • Alpine Televison... • Answered on Feb 28, 2022
NEW REMOTE FOR ALPINE IVS W 505 WILL NOT WORK
Contact Crutchfield, as they supply nearly all of these. Did you try fresh batteries in the remote, they may be 10 years old. It may also be that the new remote is faulty. Use the front facing selfie camera in your smartphone to see if the IR transmitter lights up? https://www.google.com/search?q=ALPINE+IVS+W+505 ..
12/5/2021 1:38:55 AM • Alpine Televison... • Answered on Dec 05, 2021
Hola ...nesecito el code de alpine A06012
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
2/11/2017 3:29:47 AM • Alpine Televison... • Answered on Feb 11, 2017
I bought an alpine AL55 universal remote and I don't know how to program it. does anybody know how to do that with this particular remote
In my (limited) experience I find most universal remote controls have an instruction manual that can be downloaded from the parent website where you will usually also find a helpline number. I hear the helplines are quite helpful.
3/2/2016 3:40:58 AM • Alpine Televison... • Answered on Mar 02, 2016
I need code for alpine estere by control huayu
2/29/2016 11:06:06 PM • Alpine Televison... • Answered on Feb 29, 2016
Codigo para un estereo alpine control universal huayu
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls. Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
2/19/2016 7:42:32 AM • Alpine Televison... • Answered on Feb 19, 2016
I need code for alpine estere by control huayu RC-820J+
271, 280, 219. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls. Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
2/19/2016 7:41:57 AM • Alpine Televison... • Answered on Feb 19, 2016
After we replaced the trunk
It is very likely that the latch is not centerd properly in alignment with the catch. The solenoid that drives the locking mechanism is not very strong and requires perfect alignment. You may want to try loosening the holdown bolts a little and closing and opening the hatch a few times then tighten the bolts down again. Thank you, Dana
10/5/2009 4:46:38 PM • Alpine Televison... • Answered on Oct 05, 2009
I want to change the
there are no region hacks for this in-car overhead dvd player, i can offer you an alternative if you want?
11/28/2008 3:47:34 AM • Alpine Televison... • Answered on Nov 28, 2008
No audio from Alpine w205
Thank you for the follow up.  Wee figured it out using manual and luck.
6/3/2008 3:08:29 AM • Alpine Televison... • Answered on Jun 03, 2008
Alpine New Original RUE-4151 Remote Control Logo
3 questions posted
Top Alpine Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Alpine Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Televison & Video
Most Popular Question
setting button alpine navi ine z928hd
  • Televison & Video
