20 Most Recent
Panasonic PT-AE2000U Projector Questions & Answers
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
1/4/2012 10:04:43 PM •
Panasonic...
Answered
on Jan 04, 2012
I have an panasonic pt-ae2000e
The sound must be sent to an external amplifier system and speakers.
Audio cables must be connected from each peripheral device directly to the audio reproduction system
3/29/2011 12:14:33 PM •
Panasonic...
Answered
on Mar 29, 2011
Panasonic PT-AE2000U All three HDMI Ports stoped
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
10/1/2010 2:29:41 AM •
Panasonic...
Answered
on Oct 01, 2010
RS 232 control
..did you ever solve this? i am trying to write some code to do the same thing with no luck at all. and the manual does not seem to help much besides letting me know that I have to use 'PON' and pad it with a start bit and an end bit. i find nothing online as well.
6/28/2010 5:43:10 PM •
Panasonic...
Answered
on Jun 28, 2010
Panasonic KX-MB2025 Toner Low Problem???
Does the machine say replace drum or toner. Two different units. If toner did refill or install a new toner. There is a chip on most drums and toner to tell the machine they are new. if you refill the toner the chip is still going to tell the machine it is used.
