20 Most Recent
Toshiba Satellite M205-S7452 Notebook Questions & Answers
Toshiba m205 wont open
no ligths
If you are getting power to the laptop with either the battery or an AC adaptor known to be good and there are no lights , not even the charger light or power light, then it is possible that the fuse on the motherboard has gone, I'd be inclined to take it to a repair shop for a more detailed check
12/30/2010 12:09:28 PM •
Toshiba...
Answered
on Dec 30, 2010
My Toshiba Satellite M205-S7452 laptop keeps
Most likely this is an overheating situation. If your CPU is running at over
60 degrees you might be at risk of burning it out. Some systems shut
down automatically when the temperature reaches an unsafe level.
If you determine that
overheating is not the problem, the most likely suspect is bad memory.
The best way to find the culprit is to pop open the system unit, remove
(or replace) one RAM stick and see if the problem is solved. Run your
system for a while and if the problem goes away, you win!
If not.lather, rinse and repeat for each RAM stick until you find the one that's misbehaving.
1/19/2010 10:30:40 PM •
Toshiba...
Answered
on Jan 19, 2010
I dropped my laptop and now when I start it up it
Find out what hardware it is talking about if you can. Even if the hardware in question is broken, a lot of the parts for laptops are modular i.e. you can replace them without having to replace the entire motherboard. HP laptops are probably the best at this beucase their motherboard is only a giant controller, as opposed to having every single device built into the motherboard. It would be best if you told us the type of laptop you have.
There is also the chance that the drop caused the hard drive to become damaged, in which case, restoring the damaged files would be the quickest way to fix it. I would not recommend trusting that hard drive anymore though, I would get a backup of some sort going, even if it doesnt look like it is the hard drive.
7/3/2009 3:32:55 AM •
Toshiba...
Answered
on Jul 03, 2009
Setup did not find any hard disk drivers installed on your...
dear friend
you need to goto bios and search for and option "sata native support"
set it to disabled
if
you cant find that , then you need to splitstream sata drivers into
windows xp cd, if this is the case please ask me to tell you the method
thanks
4/10/2009 6:37:32 PM •
Toshiba...
Answered
on Apr 10, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
How can a fix error code oxcoooooof
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
3/19/2020 10:52:50 AM •
Toshiba...
Answered
on Mar 19, 2020
How to play a DVD on Toshiba Satellite Pro C850
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
3/11/2020 8:58:46 AM •
Toshiba...
Answered
on Mar 11, 2020
My computer does not connect to wifi and only show
Hello,Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it. You can use
RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer. Davidhttp://goo.gl/CxsY9u
9/25/2019 4:52:00 PM •
Toshiba...
Answered
on Sep 25, 2019
