20 Most Recent
Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Oven shuts off
Good Afternoon Mark,
I see that you're having trouble with your Frigidaire range, model# PLCS389DC, shutting off in mid-baking, and will not restart until the oven has cooled. It sounds like it is either the temperature sensor, that is sensing a runaway oven temperature, or the control board itself that might need replacing. I suggest contacting you local authorized technician for further assistance. They will be able to determine what exactly is causing your oven to cut off in mid-baking.
-Best Regards-
WP
Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Oven door hinges broken
I suppose the door and hinge will need replacement. What is the exact model so i can get you a price quote for a replacement door including shipping and possible locations to purchase the door. Hoping to hear from you soon.
My front left buner won't
hi - theres a few things you can try out tp see how good or bad the problem may well be.
1 - use a match to light the burner as normal to see how good the gas flow is - press & turn the knob so it starts to ignite but using a match it should work ok.
2 - if the above works firdt time - then the problem lies with the puiezo electric igniter not gettingh a good path to earth.
- to fix this sort of problems one needs to give the burner metal parts a very good clean of the fat/grease build ups - you will notice when the ignitor arcs it most probably runs all over the place. Further where its arcing to the frame these areas need to be cleaned with those green rough cloth used to scrub pots etc. it will remove the grit and lightly expose a bit of metal to make a better contact for the system to flash over..
Cheers
