20 Most Recent Canon MP970 Photo All-In-One InkJet Printer Questions & Answers
2answers
Error message
Check these links:
http://forums.linux-foundation.org/read.php?25,2500,6496,quote=1
http://www.fixya.com/support/t765199-inner_cover_open
12/1/2018 11:07:23 AM • Canon MP970... • Answered on Dec 01, 2018
My Canon MP970 will not
What application and file type are you attempting to print?
9/12/2017 6:19:47 PM • Canon MP970... • Answered on Sep 12, 2017
3answers
NEED PRINTABLE PDF FILE OF REPAIR MANUAL FOR CANON MP970
Here you go:
http://www.tradebit.com/filedetail.php/4981055-canon-pixma-mp970-printer-service-manual
7/22/2017 6:53:28 AM • Canon MP970... • Answered on Jul 22, 2017
MP970 won't take paper from rear tray
Replace the printer is the best suggestion unless this is a very high end unit.
5/19/2017 11:22:52 PM • Canon MP970... • Answered on May 19, 2017
How do I save a scanned document to my computer?
right click on it then save
3/6/2016 11:28:22 AM • Canon MP970... • Answered on Mar 06, 2016
How to fix u052
printhead not installed or wrong printhead or printhead is dead:( try to clean contacts on printhead and replace it again
8/10/2014 11:39:11 AM • Canon MP970... • Answered on Aug 10, 2014
0answers
0answers
Error code 1500
Be the first to answer 12/26/2011 9:33:12 PM • Canon MP970... • Posted on Dec 26, 2011Be the first to answer
Canon mp970 error u051
Are u getting problem on refill catridge?
its a common problem after getting refilled cartridge.... U can use a new catridge.........
7/22/2011 11:40:08 AM • Canon MP970... • Answered on Jul 22, 2011
CLEAR A PAPER JAM FROM CASSETTE FEED
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
7/11/2011 10:51:52 PM • Canon MP970... • Answered on Jul 11, 2011
I con not use my
hi,
please browse the following
www.printerproblemsolved.co.uk/I have problems with paper feed and cannot seems to be able to sort it out, I would like to open .... my printer come up with a error code 5100 canon mp970 .
5/28/2011 8:09:57 AM • Canon MP970... • Answered on May 28, 2011
Canon MP970 5100 error
I had this same problem. I took a flash light, moved the ink carriage and was able to feel around and find a small wad of paper. After removing it, I noticed a large amount of ink build-up running along UNDER the ink carriage. I took a damp Q-tip and got off as much as I could. To my surprise, it worked.
4/12/2011 12:52:09 PM • Canon MP970... • Answered on Apr 12, 2011
Error code 6800. Lights on computer are flashing
The service error 6800 means that a problem occurred in reading from or writing to the EEPROM. To fix this you need to replace the logic board. For replacement you can try http://www.partsalliance.com or http://www.ppsnj.com
4/1/2011 4:58:48 AM • Canon MP970... • Answered on Apr 01, 2011
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette.
  2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension.
  3. Press the Paper Feed Switch to select the paper source where you have loaded paper.
  4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
3/1/2011 5:11:53 AM • Canon MP970... • Answered on Mar 01, 2011
Canon MP970 Photo All-In-One InkJet Printer Logo
81 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
printer smearing black ink all
  • Office Equipment & Supplies
