20 Most Recent
Mustek DV520T Digital Camera Questions & Answers
DV526L
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
I lost the cd that
Its actually easier to do it all manually:
7. How do I transfer pictures from my Mustek camera to a computer? Use the USB cable provided in the package to connect your camera to a computer. Please first set the USB mode of video camera into "Mass Storage" option on the camera's LCD screen and press OK. Follow the instructions below to complete the process:
a) Power on and press menu button to enter "Setup".
b) Press the up / down button to select "USB Mode".
c) Press the right button for 2 options: "Mass storage"; "PC camera". And select "PC CAM" and press "OK"
Note: Make sure you connect to your computer (NOT to a USB hub).
- Go to MY COMPUTER.
- Double-click REMOVABLE DISK drive.
- Double-click DCIM folder.
- Double-click 100Media folder.
- Click EDIT then choose SELECT ALL. (All files are highlighted after clicking SELECT ALL).
- Click EDIT and select COPY.
- Open a folder you wish to transfer your files to.
- Click EDIT and select PASTE.
Formatting memory card
Formatting Memory Card
A new SD card shall be firstly formatted before use.
a.) Select (Format) to enter into property list.
b.) Select “NO” to cancel the formatting. Select “YES” and press (OK) to execute the
formatting.
c.) All the contents in the memory will be cleared after formatting.
About Memory Card
The external card supported by this camera is SD card.
To use a new SD card, you have to format it firstly.
Maloperation may cause damage to or deletion of the data recorded.
The loss arising from deletion of recorded data will not be the manufacturer's
responsibility.
Electrical interference, static electricity and failure of video camera or memory card
might damage the data in the card. Therefore, it is suggested to transfer the data to
your computer timely.
Never take out the memory card or turn off the video camera when reading or writing
the data.
Never put the card under high temperature or high humidity.
Never modify or tear down it.
Cheers.
Mustek dv520t digital vidio camera
Hi there, in first replace or check USB cable( it may be have short circuit or is torn off.) If you use OS Windows98 need install driver, if WindowsXP not install any driver, if you install driver in WindowsXP, removed it. For viewing pictures needed install Blaze Video Magic and/or Ulead Photo Express. Read owner's manual, page 40 4.2 Connecting to computer. Manual and driver for Win98 you can get from http://www.mysilvercrest.de/en/artikel.php?a=93&av=2
SilverCrest DV77 is full similar Mustek DV520T. Cheers.
Mustek DV520T
Hi there. Sorry, but Mustek DV520T CD written only for OS Windows98/XP. Cheers.
When i turn on the
Hi there, if all files from camcorder load to your computer and you can see all yours pictures, problem can be in display cable via damage wires. Besides the reason can be a crack in the screen or damage of electronics components SMD.
Display - mobile part and connect to camcorder bunch from 21 of the flex isolated wire. At use is always bent and once breaks. Of enough breakage of one wire and screen will not show. To define it it is not difficult, but is necessary for this purpose the complete disassembly camcorder, besides it is necessary to have spare wire connector. The repair of devices on SMD components is carried out through special equipment of the soldering, special oils and fluids, SMD rework station and microscope for assembly. Sorry, but if you not make it, never begin. Cheers.
Not doing anything
I have a Mustek DV520T camera
Hi there. If you have cradle for camcorder, you can recharge battery from computer via USB cable. If you not have this, you can remove battery and recharge battery from omnipotence travel charger "Goodway", it find in shops for electronics. I can transfer pictures it device if necessary. Manual for DV520T (it full similar SilverCrest DV77) you can get from
http://www.mysilvercrest.de/en/artikel.php?a=93&av=2Cheers.
I need the installation CD to download pix to my computer.
heyii check in your menu of your cam,may be you will find an option for connecting to pc through..and there select 'mass storage'..,then connect your cam with the pc and it will detect the memory in sometym and then you can access all the data.. :)
