20 Most Recent
Mustek DV-3000 Digital Camera Questions & Answers
Mustek DV300 won't take card.
Did u insert them in the right position?
Check if there is any little card icon for the way to insert.
Also try push it in until you hear a click (that should be about 1-2 mm deeper then the slot surface level.)
Home being remodeled to many different helpers ?
you people are sad . you want me to go premium hence $ and yet have the nerve to ask me to tell you how i did it in the event that i already solved the problem.how is it youcan ask me to pay for info presently offered somewhere on the net for free
How do I deliete pictures
Please follow the below link and download the manual for your camera,it will help you delete pictures from your camera.
http://nodevice.com/driver/DV_3000/get33257.html
Mustek dv3000
Try change the video out setting to "pal",press the menu button and scroll 3rd down which will show "ntsc" or "pal" press "set" to get "pal".
Never Stays On
In the menu"the middle right button" there is a auto power off mode that you may have activated just switch this to off.
Turning it on
You may have a memory card larger than 1gb which is the max you can use,over 1gb freezes the device when switched on causing your problem.
Review of pictures
With the camera in "camera mode" just press the "green rec/play" button in the top left of the touchpad.
FUNCTION OF DV3000
Damp or just dry flex ribbons inside connecting the touchpad can be the cause and opening the camera and giving it a good wipe with wd40 or another lubricating fluid(use a fine artist paint brush)may solve your problem.The camera is easy to open but when lifting the right half of the housing away(screen side) be gentle and disconnect the flex ribbon underneath or you will tear them.
Hi there
You can only use a maximum of 1gb memory card as i had the same problem with a used camera i bought and the instruction manual does not mention this anywhere.I use a 512mb card and the camera works okay.For the price,pretty impressive really.
I have no way to charge my mustek dv520t
As it is now 12 years old, I doubt if a suitable charger is still available, quite apart from the condition of the batteries after all this time. If I were you, I should bite the bullet and replace it with a more up-to-date model.
