20 Most Recent
Peavey VTB1 1-Channel Amplifier Questions & Answers
Peavey TNT 160 has no response from both inputs, only preamp in
In my experience fuses rarely blow due to age! I suspect that whatever the guy said the problem was it was really a faulty transistors or IC in the power amp board.
You can check transistors with an Ohm meter in circuit to some extent. (the ones with a scale and needle are best for this) Look for a short between the terminals of each power transistor on the heat sink first. If any transistor sends the meter full across (both ways) you have found the fault.
Special 130 Won't Power On
Hi....
Peavey puts many of their fuses on the main curcuit board inside the amp...I work on peaveys alot and that's what I'd check for 1st
Amp stopped working
check your cables,line source inputs, speakers button switches( A&B),maybe it's OFF,if it's ON, then you have a power amp. problem,see a doctor,you know what i mean.
Sanpera 1 with Peavey Viper 1 amp - no longer looping
If your Sanpera 1 pedal has suddenly stopped looping on your Peavey Viper 1 amp, it's possible that there's a hardware or internal issue. It's recommended to contact Peavey customer support or a professional technician to diagnose and resolve the problem.
How do I troubleshoot this mic?
Check the coil resistance, first on the capsule (unscrew the front screen) and then on the No. 2 and 3 pins on the XLR.
Now you know....
Probably your membrane coil went away.
That happens, so sorry, but check...
Peace-
