20 Most Recent
KitchenAid 30 in. Architect II Series 4.3 cu. ft. Double Convection Steam Oven - KEBU208SSS Dual Questions & Answers
My oven door glass was dirty, from the vents in
the glass pieces should only fit back in one way, holes will only go one way , as far as the hinges, the need to be locked open in order to replace back into the unit, there is either a small hole in corner of hing that when pushed wll align with another hole in hing allowin for a thin blade screwdriver to be inserted adn hold in hte locked position,... the other way is a small locking mechanism is loacated on the top of hinge that when fully extended will lock hinge open for reattachment... you would need to REALLY PRESS that hinge to lock in place..
Error message F7-EO
turn the circuit breaker off for about 15 mins. turn it back on and it might reset itself. let me know if it works!!!
I have the Kitchenaid Superba Convection wall oven Model KEBS207DBL1 and it won't stop beeping. Shows error code F2 e3 at times. Is there a fix?
This typically indicates an issue with the touchpad or control board. Here are some steps you can take to troubleshoot and potentially resolve the issue:
Check the Cable Connection: The error code could be due to the touchpad cable being unplugged. Ensure a proper connection between your appliance's touchpad and the control board.
Power Reset: You can try resetting the oven by turning off the fuse or circuit breaker, waiting for 1 minute, and then turning it back on. Repeated power restarts may allow the oven to reset and resolve the issue.
Replace the TouchPad or Control Board: If the connection is fine and the error code persists, the issue might be a malfunctioning touchpad or a fault on the control board. In such instances, it's recommended to replace these parts entirely. Please note that this should be done by a professional to ensure safety and correct installation.
