20 Most Recent
KitchenAid KEMC378 Electric Double Oven Questions & Answers
Kitchenaid superba
switch off electricity to oven, then switch it back on - that reboots the computer that controls the oven.
"door"
your door or interlock switch is not closing press on the door see if it stars if so you will have to check you alignment if not the switch could be bad you wuill need to open the ctrl panel to get to the switches unplug first
Getting an error message from
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part,
http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
FixYourBoard.com
What does error code F1
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit.
The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter?
I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Error code E6 F2
F2 - E6
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
How do I change the
the light cover at the back of the oven needs to be unscrewed. There is normally 2 or 3 little screws involved. Once it has been removed it's like any other light bulbs, unscrew and change. Make sure to put back the cover tightly in place or the light will burn when the oven turns on.
My KEBS278 superba electric double oven is showing
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Err F1E0 Replace Oven UI
The part CNTRL-ELEC solved our problem. The warranty repair person replaced it and it has worked fine for a week now.
