20 Most Recent
Insignia NS-7PDVD Questions & Answers
Setting up my insignia tv to cable
If you need to set your TV up for a cable connection, please enter the on screen Menu, then select Channels, then (depending on your model of TV) Video or Signal source. You should have two or three options: Cable, Cable/Satellite box, or Antenna. Select Cable if you will not be using a set top box. More details on selecting the signal source and setting up your Insignia TV can be found in the User Manual. If you need a copy, please visit
InsigniaProducts.com, search for your TV model number, then click on the Support/Downloads tab.
11/4/2011 12:39:59 PM •
Insignia...
Answered
on Nov 04, 2011
IT WILL NOT TURN ON
U tries used it a A/C power adaptor itself?Power a/c adaptor might be bad or tries power it on by the litium battery it don't work ethier?No,might require replacing a new litium battery.
3/21/2011 9:43:53 PM •
Insignia...
Answered
on Mar 21, 2011
Player will not load the dvd
If this is a problem on multiple DVD's then try to run a DVD disc cleaner. If it's only on a particular one, then either it's not formatted properly or physically damaged.
3/1/2011 3:54:00 PM •
Insignia...
Answered
on Mar 01, 2011
The player keep saying no
If optical laser lens got dirty or defective, dvd player will show 'no disc' display after a while.
Clean optical laser lens with good quality cotton swab gently, put dvd disc in payer and check.
If problem does not solve then optical laser block will be replaced to solve the issue and local tv repair shop will do the job because it needs expertise and skills.
Hope this info will help you.
Thanks.
6/30/2010 2:52:53 AM •
Insignia...
Answered
on Jun 30, 2010
It had a smell like something was burning. Now
The main PCB board have burn parts,take it aparts and check it by ur self.Replaced parts by ur self.If u want it to repair by the shop don't,not worth repairing.U can get new one pretty cheap.
6/18/2010 8:19:57 PM •
Insignia...
Answered
on Jun 18, 2010
ORDER CHARGER
http://bestbuy.partsearch.com/ModelSelect.aspx?MfgName=Best+Buy+Company+Incorporated&BrandName=Insignia&ModelNumber=Insignia+NS7PDVD&PartCategoryName=DVD+Player+AC+Adapters+%26+Chargers is the place to buy chargers
6/2/2009 12:58:56 AM •
Insignia...
Answered
on Jun 02, 2009
Insegnia NS-7pdvd portable dvd player regional lock
There is software, such as "ANYDVD" that should work. Also, "DVD Region and CSS free" software about $40 US. There is free software called "DVD Region Killer" as well (I have no experience with the free downloadable software).
4/18/2009 4:54:06 PM •
Insignia...
Answered
on Apr 18, 2009
Half the screen is on the other is off
the effect ot moisture due to humidity.this may cause this .two possibilities keep the unit ON for some hours it will automatically get perfect.or the other that the circuit internally has gone short so its showing this problem.if short it needs reparing.
if under warranty will get replacement.
thanks.
1/5/2009 4:35:46 AM •
Insignia...
Answered
on Jan 05, 2009
