20 Most Recent Insignia IS-DVD1001 DVD Recorder/VCR Questions & Answers
The TV seems to have a failing Power Supply. This could potentially be repaired but would be an out of warranty expense.
Insignia... | Answered on Dec 14, 2017
If the take up reel is not working properly the slack in tape drive will cause poor recordings and shut downs.
Insignia... | Answered on Sep 13, 2017
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Insignia... | Answered on Jun 03, 2016
I would check the connections to make sure they are good. The video connection could have gotten knocked loose. Sometimes they just come loose.
Insignia... | Answered on May 15, 2014
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
Insignia... | Answered on Feb 26, 2013
Insignia IS-DVD1001 DVD Recorder/VCR Logo
207 questions posted
Top Insignia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
remote did not work ordered
  • Televison & Video
